Foopid stucking question time.
Discussion in 'UK Motorcycles' started by SD, Aug 30, 2006.
  1. SD
    SD Guest
    How does one format a C: drive, when the "volume is in use".
    BiL has decided to start from scratch in the wake of virus and spyware
    infestations.
    He knows less about computers than me, if you can imagine such a
    person.
    | ___ Salad Dodger
    |_\_____/_| ..83466../..22358.../..31893.
    '^' RBR Clues: 52 Pts:1005 Miles:3416
    SD, Aug 30, 2006
  2. In uk.rec.motorcycles, SD belched forth and ejected the following:
    Boot from a DOS disk and format C: at the command prompt.
    You might need to change the boot sequence to start with your CD drive
    if you ain't got a floppy, innit.
    Whinging Courier, Aug 30, 2006
  3. SD
    Steve Parry Guest
    If he's installing Windows 2000 or Windows XP Pro/Home then theres an option
    to format the partition during the reinstall procedure.
    I normally delete the existing partition, when offered during install, and
    format after.
    Steve Parry, Aug 30, 2006
  4. SD
    Scraggy Guest
    If it's XP, use the CD
    http://www.theeldergeek.com/formatting_drives_using_xp_cd.htm
    Scraggy, Aug 30, 2006
  5. Boot from the recovery/widows/floppy disk and it will reach a format
    stage choice.
    Grimly Curmudgeon, Aug 30, 2006
  6. SD
    Cab Guest
    Completely dead, is it?
    Cab, Aug 30, 2006
  7. SD
    gomez Guest
    But not before backing up your personal data, I trust?
    gomez, Aug 30, 2006
  8. Blown into the weeds.
    Grimly Curmudgeon, Aug 31, 2006
  9. SD
    catman Guest
    Obviously. He can't if he's booted into the OS on the C drive. As
    everyone else has pointed out (sort of) he needs to boot off something
    else, typically the OS install disc, which will almost certainly have a
    format option along the way.
    www.cuore-sportivo.co.uk
    catman, Aug 31, 2006
  10. Boot from the install CD (either change the boot order in the BIOS or -
    if he has a modern BIOS - hit the key that gives you a boot menu from
    the BIOS) and let it go ahead.
    During install tell it to do a fresh install and delete the C
    partition. Recreate the C partition and let Windows format it.
    Jobs a good'un.
    Phil
    Phil Launchbury, Aug 31, 2006
  11. SD
    Steve Parry Guest
    Personal data at home and work is on servers so no probs there
    Steve Parry, Sep 1, 2006
  12. SD
    SD Guest
    Al sorted now, ta for all the help.
    | ___ Salad Dodger
    SD, Sep 1, 2006
