For Dodger (and any other CBX fiends)
Discussion in 'UK Motorcycles' started by The Older Gentleman, Dec 12, 2009.
  1. Rather nice animation of a CBX engine assembly.
  2. Click on the progress bar a few mm into the vid - for some reason it
    didn't start instantly for me either.
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Now that, right there, is a man in desperate need of getting laid.
    Really.
    Wicked Uncle Nigel, Dec 12, 2009
  4. The Older Gentleman
    Nice? Not the word that comes to my mind.
    Why?
    is the first, quickly followed by "for" then "****'s" and "sake".
    Ace, Dec 13, 2009
  5. The Older Gentleman
    Dave Emerson Guest
    My thoughts exactly.
    Dave Emerson, Dec 13, 2009
  6. The Older Gentleman
    Blimey, a bit anal.
    So was that a CAD package, an animation package or what?
    And do CBX camshafts really come in two major pieces?
    Pip Luscher, Dec 13, 2009
  7. The Older Gentleman
    Cane Guest
    I lasted less than 30 seconds ...fnarr
    Cane, Dec 13, 2009
  8. The Older Gentleman
    Salad Dodger Guest
    Yes. And the joiny bits in the middle wear out.
    Just another piece of "characterful" engineering insight from the
    mighty H.
    Like two camchains, and an alternator with a clutch.
    Salad Dodger, Dec 13, 2009
  9. Yes. The joint is known as an Oldham Coupling, presumably because it's
    used to old 'em together.
    The Older Gentleman, Dec 13, 2009
  10. The Older Gentleman
    <shudder>
    Crude bastards.
    Andy Bonwick, Dec 13, 2009
  11. The Older Gentleman
    Pete Fisher Guest
    In communiqué <1jaod29.100z0rb1tn55moN%>,
    Bloody hell, isn't memory a peculiar thing. I just turned almost
    straight to the page (150) in the gospel according to St Phil about
    them. Cammy singles in that case though.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 13, 2009
  12. The Older Gentleman
    A fine old Japanese engineering company, I'm sure.
  13. The Older Gentleman
    crn Guest
    Grone.
    crn, Dec 13, 2009
  14. The Older Gentleman
    Well if you were drivng twenty-four valves off one roller chain, I
    could sort of understand it. But... looking at the animation again,
    first, the sprockets look more like gears, which implies Hy-Vo chains,
    and the camshaft sprockets seem to be offset, which implies that there
    are two crank-to-camshaft chains, but there seems to be only one
    sprocket on the crankshaft.
    Surely they don't slave one camshaft off the other? It's just the
    animation, right?
  15. They do.
    Same with the CB750 and CB900 fours of the same era.
