For the grinder fans
Discussion in 'UK Motorcycles' started by Eddie, Jan 6, 2006.
  1. Eddie
    Eddie Guest
    No, not angle grinders.
    *Bench* grinders. Cheap.
    Aldi are selling them, GBP11.99 for a 200W grinder, comes with one fine
    and one coarse wheel. Seems like a bargain to me, and should be good
    enough for my purposes.
    They're also flogging pairs of extra wheels for GBP2.99.
    Now, what needs sharpening? All my knives, scissors, the mower blade,
    axe... ummm... pizza cutter... damn, there must be other stuff...
    Eddie, Jan 6, 2006
  2. Eddie
    Vass Guest
    Can you stick a polishing wheel on those things ?
    My pipe has moulded Sidi boot rubber on it from my heel
    I'd rather like to get it off and I think a grinding wheel may be slightly
    too abrasive
    Vass, Jan 6, 2006
  3. Eddie
    Eddie Guest
    Oooooh... cutting.
    Eddie, Jan 6, 2006
  4. Eddie
    You'd be much better off with a power drill attachment-type selection
    of polishing mops and compounds, like this:
    http://www.axminster.co.uk/product.asp?pf_id=22995&src=froogle
    I have a similar kit and use the drill either hand-held or mounted in
    a Workmate depending on the size and accessibility of the item. The
    coarse mop and compound remove "Not For Road Use" markings
    effectively, the finer mops polish metal to a fine lustre. As used in
    the production of the Champion-105 exhaust hanger, as it happens.
    Pip, Jan 6, 2006
  5. Eddie
    Eddie Guest
    I found it rather dull.
    Eddie, Jan 6, 2006
  6. Eddie
    Eddie Guest
    Hardly cutting-edge, was it?
    Eddie, Jan 6, 2006
  7. Eddie
    Post a link to the photos showing the 'incident' when you change the
    wheel for the first time.
    Andy Bonwick, Jan 6, 2006
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    My thoughts precisely. Cheap grinder wheels... <shudder>
    Wicked Uncle Nigel, Jan 6, 2006
  9. Eddie
    zymurgy Guest
    Safety nazi.
    My grinders wheel is horrendously worn at an angle to one side at the
    moment. I had to grind down a CrMo socket into 4 prongs to get the
    'special nut' off the honda clutch basket.
    Hmm, cheap wheel dresser on cheap wheel ...
    P.
    zymurgy, Jan 7, 2006
  10. Eddie
    Hey, I'm all for Darwinism.
    I wouldn't mount any wheel without balancing it but cheap shit can't
    be balanced. Dressing doesn't balance a wheel, it might true up the
    face but they're still out of balance which means you risk it
    exploding every time you start the fucker up.
    Andy Bonwick, Jan 7, 2006
  11. Eddie
    Vass Guest
    Like it, thanks Pip
    Vass, Jan 12, 2006
