Fork oil weight
Discussion in 'Australian Motorcycles' started by Duncan, Sep 25, 2005.
  1. Duncan
    Duncan Guest
    Hi,
    I've just replaced the fork oil and seals on my 99 ZX-6R. Once the bike was
    back together I noticed the forks were very stiff, I backed off the damping
    adjusters and the forks were back to normal.
    I then discovered that while the service manual says to use 10 weight oil, I
    had racetech valves put in a while ago and they put in 5 weight oil.
    My question is, is it bad to be running the racetech valves with 10 weight?
    I'm still able to get the damping I want but it's very close to the limit on
    the damping adjustment.
    Cheers,
    Duncan.
  2. Duncan
    Bummers Guest
    It won't hurt a thing but the range of (softer) adjustment you used to have.
    Bummers
    Bummers, Sep 25, 2005
