Fork Seals - Help Required Please
Discussion in 'UK Motorcycles' started by Mark, May 25, 2005.
  1. Mark
    Mark Guest
    I have a second gen 2001 model Bandit 1200S and have replaced the fork seals
    but still have a slight leak.
    On following the Clymer manual it states that the seal open end should face
    upwards. I have interpreted this to mean the side with the spring faces up
    towards the handlebars. The problem is the Haynes manual shows picture and
    the seal appears to be a different way up in different pictures! I have
    installed the seals a different way up than the old ones so I am not
    confident that I have got it right.
    Any help appreciated.
    Thanks
    Mark, May 25, 2005
  2. Mark
    Mark says...
    I think you got it wrong. I've never seen a fork seal fitted that way
    up before.
    Lozzo, May 25, 2005
  3. Mark
    Martin Guest
    Just curious, but why would you install a seal in a different way to the
    original seals and the Haynes manual? I take it the Clymer manual
    doesn't have pictures to guide you?
    In short the side with the springs should be inside the tube.
    Martin:
    VTR1000 Firestorm
    Martin, May 25, 2005
  4. Mark
    Yeh, I'd tend to agree with that. Springy side in is the only way I've
    ever fitted seals, apart from one seal that had a spring on both sides.
    In that case, I fitted the smaller diameter double lipped part of the
    seal facing oil side.
    Muck, May 25, 2005
  5. Mark
    Eiron Guest
    Many bikes have the spring side of the seal on the top.
    Unfortunately a Bandit doesn't have upside-down forks.
    Eiron, May 25, 2005
  6. Mark
    Many Binned-its spend much of their existence upside down - or at
    least, attempting to be.
    Pip, May 25, 2005
  7. Wrong. Very, very wrong.
    The Older Gentleman, May 25, 2005
  8. Mark
    Mark Guest
    "The Older Gentleman" wrote
    : Wrong. Very, very wrong.
    Thanks to all...............I guess it's another couple of hours stripping
    and rebuilding for me then. I will attempt to reuse the seals but I bet a
    third attempt wont be far behind!
    Mark
    Mark, May 25, 2005
  9. Don't.
