For fucks sake, one has let go in a big way, just bouncing the bike up & down makes it drip out. So, lets hope it can sorted for Monday or thats job fucked. -- Nige, 'That's shot the fox' Eunos Roadster (for summer) Grand Cherokee (for winter)
You'll be lucky. Unless you can spend Friday taking the offending leg out yourself and toting it to a dealer on the Saturday.
Thank **** for Firefox racing in Keighley, ride in, new seals, oil & general checkup & ride out £85 for both forks... Might get them to install k-tech valves & he'll setup the suspension for me, too. A bit of fucking about with trains dropping it off, but the alternative would be losing the £149.... -- Nige, 'That's shot the fox' Eunos Roadster (for summer) Grand Cherokee (for winter)
At that price, I'd strongly suspect they use one of those horrible claw tools for yanking out the seals without separating the fork leg and stanchion. If that's the case, I'd avoid.
I know the chap that works there, i bought my ducati 916 off him. They do a decent job, i might also get some valves k-tech. He's the sort of bloke that would invite you to watch him do the work. My view would be that they do so many fork rebuilds & rear rebuilds they can do 'em cheaper. And they do a *fucking* lot. BTW, how do the claw things work with regard to getting new seals in? I have seen 'em, but... -- Nige, 'That's shot the fox' Eunos Roadster (for summer) Grand Cherokee (for winter)
Well, OK, but I'd reckon it would take, let's say 10 minutes to get the legs out. Remove wheel, calipers, mudguard, gubbins, etc, undo pinch bolts, drop legs. And thus 10 minutes to replace. Put leg on bench, undo securing bolt that holds leg and stanchion together, upend leg, drain oil, remove all damping internals, carefully lay them out in the right order on the bench, clean out leg of all old oil, remove seal, fit new seal, clean and replace damping internals, carefully measure and fill fork oil, check level, bolt leg together. Probably 30 minutes per leg. You're up to 80 minutes for the job. Add cost of fork seals - close to a tenner each these days for exotic stuff. Plus a bottle of fork oil; another fiver. Labour rate of £40 an hour? So say £50 for labour. Plus seals and oil. OK, just possible if they work like demons. I'm assuming, btw, that that £85 includes VAT at 20%. You have, like, two parallel hooks on the end of a handle. You bang the sharp ends of the parallel hooks into the seal wiv an 'ammer. Then you lever the seal out, using the edge of the fork leg as a fulcrum. It's terrifying easy to damage the lip of the leg.
