Fork seals
Discussion in 'UK Motorcycles' started by garryaca, Jun 28, 2007.
  1. garryaca
    garryaca Guest
    Changing fork seals....is it difficult? PS its the dreaded MZ 150
    again ! Sorry...! :)
  2. garryaca
    TOG Guest
    It's a relatively easy job *if* you have the right tools and know what
    to do (same as anything, really). The hard job can be separating the
    leg and stanchion. Oh, and also, for the newbie, getting the new seals
    in square.
    Top tip - heat up the leg in the oven to about 100 degrees C before
    removing/fitting the old/new seal(s). It makes the job a lot easier.
    TOG, Jun 28, 2007
  3. Itym Araldite.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Jun 28, 2007
  4. And fer ****'s sake make sure the bike isn't sitting on the front wheel
    when you take the second fork cap nut off.
    GS850x2 XS650 SE6a
  5. Yebbut superglue often isn't too resistant to water and may just fall
    off.
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Jun 29, 2007
  6. That's just stupid. I mean, that would be as stupid as remembering your
    bike tilted backwards on the centre stand when you remove the front
    wheel, thus not requiring the use of a front paddock stand. Remembering
    that would be fine, but then just as the bike falls to the floor[1]
    forwards when you remove the front wheel you remember something else -
    that you filled it up with petrol on the last ride - thus changing the
    CoG sufficiently to make the tilt a forward one.
    [1] No damage luckily
    mike. buckley, Jun 29, 2007
  7. Different types, I suspect, then. I've certainly had superglued stuff
    fail when wet.
    GS850x2 XS650 SE6a
  8. garryaca
    Do you need to?
    If it's just weeping rather than gushing then simply removing the
    stanchion and wiping the seal and rebuilding with fresh oil (ATF) should
    do it.
    sweller, Jun 29, 2007
