Four candles
Discussion in 'UK Motorcycles' started by MikeH, Jan 29, 2008.
  1. MikeH
    MikeH Guest
    Oh alright, four xeals.
    Having noticed that one of mine has gone a bit damp on the dust cover
    (I've read the manual so I know this is a cover and not the actual seal)
    I'm going to have to get the seals replaced.
    I suspect the cause may have been the omigod moment yesterday when I
    rode over a bit of wood that jumped off the back of a lorry going the
    other way. Anyway
    is replacing the seals on a GSX750F as easy as the HBOL suggests:
    Bike on stand
    Remove front wheel
    Pick bike up
    Wheel back in
    Jack under exhaust
    Wheel out again
    Drop forks out
    Swear a bit
    Forks back in
    Slacken top nut
    Forks back out
    Remove top nut
    Bang tubes out, pulling seal with it
    Gently coax new seal in
    Reverse the rest of it
    Fill with fork oil
    or not?
    Several generic web articles suggest it is this simple, but I expect
    somebody on here will know for sure.
    Ta
    MikeH, Jan 29, 2008
  2. MikeH
    MikeH says...
    It's pretty much like that, only you'll neeed to undo the bolt that
    holds the damper rod in place, and that one goes in from the bottom of
    the forks. That's the fucker that will either come out easily, or will
    spin round like a bastard requiring use of Mr Suzuki's special tool to
    hold the damper rod still. Try undoing it while the forks are intact and
    spring pressure is acting on the damper rod seat. Clamp the fork in a
    vice by the caliper mounts and have a go. If it gets a little easy to
    turn, get someone strong to push the stanchion into the slider and exert
    more pressure on it. You'll find air tools are extremely handy for this
    job.
    I did the seals on my CBR600 yesterday, they were a pice of piss - but
    then again, I've done hundreds over the years so they would be.
    Lozzo, Jan 29, 2008
  3. MikeH
    Simon Wilson Guest
    Someone up there ^^^^^^^ implied that often fork seals can be removed by
    using a self-tapper screwed into the seal to yank it out. I don't think
    that would have been possible on the last set that I did, but might be
    worth a try. I've done that on camshaft and crank seals etc. in the past.
    OTOH, you may well want to dismantle them to get all of the gunge out
    that seems to accumulate in the bottom of the legs.
    Simon Wilson, Jan 29, 2008
  4. MikeH
    TOG@Toil Guest
    That can work. It's best to get the leg around the seal nice and hot,
    too: that makes removal and replacement much easier.
    There's a brutal tool that stabs the seal and then levers it out, but
    you need to be really careful with it as it's very easy to nadger the
    surface the seal sits in. The traditional way is best, and Lozzo's on
    the money here. Actually, to stop the damper rod spinning, a broom
    handle jammed down the fork leg often works.
    TOG@Toil, Jan 29, 2008
  5. MikeH
    Eddie Guest
    I used to use a suitably-sharpened piece of wood, but then I discovered
    that using an allen bit on the end of a number of extension bars (or
    similar) worked much better.
    Eddie, Jan 29, 2008
  6. MikeH
    TOG@Toil says...
    Try doing that with cartridge fork innards. No can do.
    Lozzo, Jan 29, 2008
  7. MikeH
    MikeH Guest
    If you hadn't snipped I could have just printed out one posting.
    Thanks all for the advice.
    Wait for a dealer post saying "A bloke just came in with a broom handle
    jammed down one fork leg and some self-tappers and allen bits trapped in
    the bottom of the other. Asked if it was covered by the warranty as he
    thought it was like that when he bought it."
    MikeH, Jan 29, 2008
  8. MikeH
    MikeH Guest
    Lozzo wrote:
    I haven't been outside to look, but is the damper rod something I could
    loosen with somebody sat on the bike pushing the forks down before I
    start dismantling?
    MikeH, Jan 29, 2008
  9. MikeH
    Eddie Guest
    You can't undo the damper rod without removing the front spindle, so
    probably not.
    Eddie, Jan 29, 2008
  10. MikeH
    MikeH Guest
    Aha.
    Luckily I cunningly covered myself against looking stupid by saying "I
    haven't been outside to look".
    This is known as the "I'm not stupid, I'm lazy" defence.
    MikeH, Jan 29, 2008
  11. MikeH
    Eddie Guest
    If you were /slightly/ less lazy, you could work out whether the forks
    off a 1992 GSX600F would fit your bike, and I'd sell you a very nice
    pair at a very reasonable price, thus avoiding having to undo the damper
    rod nut at all!
    This is known as the "any opportunity for a sale" riposte.
    Eddie, Jan 29, 2008
  12. MikeH
    MikeH Guest
    <shakes piggy bank>
    <picks up buttons>
    MikeH, Jan 29, 2008
  13. MikeH
    Eddie Guest
    Okay, so not *that* reasonable.
    Eddie, Jan 29, 2008
  14. Ah. No, I suppose it wouldn't work.
    The Older Gentleman, Jan 29, 2008
  15. MikeH
    DR Guest
    I still possess a length of (I think) 10mm threaded rod with two
    appropriately-sized nuts secured on each end. However that was
    appropriate for a GSX550ES; I have no idea if it would fit anything
    modern.
    DR, Jan 29, 2008
  16. God, I'd forgotten your old GSX. Wasn't that the one whose swinging arm
    pivot was actually broken in half???
  17. MikeH
    Simon Wilson Guest
    I tend to find this makes for rather a stiff ride.
  18. MikeH
    DR Guest
    Yeah, thanks, I'd managed to forget that too - it was only held in
    place by the plastic caps of the pivot tunnel. I had no idea just how
    much was wrong with that bike until I test rode the Bandit 600 I then
    bought. Some bikes are learning experiences; that one was a PhD in
    "what not to buy". I learned a lot from that bike. As my first
    post-DAS bike, I claim it as a rite of passage, of sorts...
    DR, Jan 29, 2008
  19. MikeH
    MikeH Guest
    Brilliant. I can send all these bloody pills back.
    MikeH, Jan 29, 2008
  20. Sell them via the internet. Lots of people do.
    Oddly, I was hearing the other day that spam actually works - you'd be
    surprised (I was) to find that a significant percentage of
    VigraGiantWilly spam results in orders - something like 7%, which is
    astounding in direct mail terms.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Jan 29, 2008
