French Run ferry details
Discussion in 'UK Motorcycles' started by Colin Irvine, Mar 30, 2011.
  1. Julian Sopers round this way used to make cables to order. In fact it was
    the only way they seemed to sell them. Dunno if they do mail order or,
    since it has been taken over by the daughter, they even do them at all.
    Much cleaning and degreasing first is A Good Idea.
    steve auvache, Mar 31, 2011
  2. Colin Irvine
    SIRPip Guest
    How about inadvertent selection of reverse gear? That would do it, I
    think.
    Thanks for that. I can't recall soldering nipples onto cables before -
    I assume I've done it, but have no recollection. Hobgoblinned,
    probably.
    While you're there, though ... did I see mention of a blasting cabinet,
    the other day? I've just bought a light for the chair, see, and it has
    a grille over the lens, which is part of the reason I bought it, as it
    fits the 'look'. The grille is more than a little rusty, however, and
    it will be as fiddly as hell with a wire brush in a Dremel. Would
    blasting the rust off be an answer, d'you think? I'll be painting it
    black, in any case.
    SIRPip, Mar 31, 2011
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, SIRPip
    We could certainly give it a whirl.
    Wicked Uncle Nigel, Mar 31, 2011
  4. Do they take english debit and credit cards ?
    Brownz (via Gurgle Gruppez), Mar 31, 2011
  5. Colin Irvine
    Alan Crowder Guest
    Is that the trip on the 29th April going from Dover?
    We will be behind you, not chasing mind just behind.
    Alan
    Alan Crowder, Mar 31, 2011
  6. Colin Irvine
    SIRPip Guest
    <takes the Fifth>
  7. Colin Irvine
    SIRPip Guest
    Obliged.
  8. Colin Irvine
    SIRPip Guest
    Noted.
  9. Colin Irvine
    Vass Guest
    ?Has anyone sorted a good route
    non motorway, scenic with bends a plenty
    but not full of speed limiting villages?
    care to share?
    Vass, Mar 31, 2011
  10. Colin Irvine
    Feel free to tell me I'm a twat by all means, but I've come to the
    conclusion the only reason people still solder nipples on is because
    that's the way it always used to be done. In these days of glues that
    can hold lumps of engine & airplanes together, I don't see the point of
    running the gauntlet to get a good solder joint. So the next cable I
    have to make up will be done with JB Weld.
    Krusty, Mar 31, 2011
  11. Colin Irvine
    Colin Irvine Guest
    Yep.
    Colin Irvine, Mar 31, 2011
  12. Colin Irvine
    Scraggy Guest
    Yes, but as it's from Cherbourg it would prolly be best is you used the
    péage to get there....
    Scraggy, Mar 31, 2011
  13. Colin Irvine
    http://tinyurl.com/5tl6ehw
    If you want to get there in time for dinner you don't have much choice
    but to use the motorway for at least part of the route.
    The detour via Londinieres was part of my route to Pithiviers a couple
    of years back and was an absolute hoot.
    ogden, Mar 31, 2011
  14. Colin Irvine
    Wish I was going :eek:(
    I shall console myself with the fact that my view will hopefully be a
    combination of:
    http://www.flickr.com/photos/eannuk/2690810152/
    http://www.flickr.com/photos/fromronandjudy/3828926576/
    and
    http://www.flickr.com/photos/53494017@N06/4979169994/
    CT, Mar 31, 2011
  15. Colin Irvine
    Colin Irvine Guest
  16. Colin Irvine
    ogden, Mar 31, 2011
  17. Colin Irvine
    Ha!
    CT, Mar 31, 2011
  18. doetnietcomputeren, Mar 31, 2011
  19. Colin Irvine
    Sure. It's OK. For Spanish a lager.
    Each to their own!
    CT, Mar 31, 2011
  20. Colin Irvine
    Jeremy Guest
    Do you have that route in a form where it can be uploaded to a TTR2?
    Jeremy, Mar 31, 2011
