French Run News
Discussion in 'UK Motorcycles' started by The Older Gentleman, Apr 30, 2011.
  1. All have made it to the hotel safely, but there have been some 'issues'.
    First was Dodgetr whose new Wing has a huge hole in the fairing. The
    cranking handle for winding down the landing legs on the trailer dropped
    off a truck ahead of him, hit the tarmac, bounced, sailed trough the air
    and embedded itself in the front of the Wing.
    This was a serious large piece of metal. If iot has hit his leg it would
    have taken it off.
    The truck stopped, and then the driver climbed back into his cab and
    fucked off.
    We went past as there were already two bikes in attendance and five
    minutes later it was my turn. The K went dead, or at least the engine
    did. Smoke was pouring out from behind the right-hand side panel. Oh
    dear.
    About three-quarters of an hour later, an interestingly melted section
    of obviously essential wiring had been stripped right back to bare wires
    and wrapped in HazMat tape as that was all we had available (doesn't
    everyone?).
    And it started.
    Why didn't the fuse blow? Ah, that was the first thing I checked. All
    the fuses in the box are 15 amp. Hmmmmmm.
    Bonwick's K is misfiring - Lozzo, stop laughing - and we rode through
    the biggest thunderstorm I've ever seen. Massive rain and hail.
    Last night was the usual over-indulgence and there's another happy local
    barman.
  2. The Older Gentleman
    Nige Guest
    Fucking nora, whats gonna happen on the way back?
    Nige,
    'That's shot the fox'
    Eunos Roadster (for summer)
    Grand Cherokee (for winter)
    Nige, Apr 30, 2011
  3. If previous form is anything to go by someone will end up coming home by
    AA relay having run out of magic smoke a mile or so before the ferry and
    someone else will get a good nicking for being a little too enthusiastic
    with the throttle on that lovely swoopy bit on the M20 and a third party
    will run out of petrol when he finds out his Platinum Ego card doesn't
    work in foreign.
    steve auvache, Apr 30, 2011
  4. The Older Gentleman
    Nige Guest
    First one i went on i nearly ran out of fuel, it spluttered into the
    services & i was shitting bricks.....
    Nige,
    Nige, Apr 30, 2011
  5. The Older Gentleman
    crn Guest
    Hmmmm - new plastics and a new loom at least.
    Sounds like the inn sewer ants might write it off.
    crn, Apr 30, 2011
  6. Utter bollocks.
  7. The Older Gentleman
    Mups Guest
    Hotter bollocks you say?, bloody well will be if you don't fix that
    wiring loom.
    Mups, Apr 30, 2011
  8. The Older Gentleman
    boots Guest
    He does have a reputation to uphold.
    boots, Apr 30, 2011
  9. Heh. A call to Brian Giles elicited the information that the section of
    wiring that fried is the lead to the sidestand cut-out and that the jack
    plug can simply be shorted across to bypass it. A paper clip and some
    tape would do it.
    The damage to the wire got less the further way it was from the point
    where it shorted to earth. Where it enters the loom proper there's
    definitely signs of heat, but not total destruction as there was lower
    down. I'll have to remove some of the wrapping off the main loom and see
    just how bad it is - see of the pants says it's probably not badly
    damaged enough to warrant replacement, but if it is it's just these two
    wires.
    Covered about 120 miles today on a bimbling sightseeing tour with some
    others, and it's running fine. Fingers crossed: I'll sort it properly
    when I get home. If.
    Other ukrm-ers were visibly impressed at the bodge that got it going
    again. Cameras were clicking.
    Meanwhile, Bonwick has had the coils off his K1100RS and has cleaned up
    all connections, sprayed WD40 everywhere and is hoping for a miracle.
    Dodger says he's going to chrome the huge piece of metal that struck the
    Wing. The hole in the fairing is bad enough, but it's done some internal
    damage to the headlight adjustment system (electric) and a fairing
    fastener exited into his lap through one of the air vents.
  10. The Older Gentleman
    Nige Guest
    You **** sheep in the arse.
    Nige,
    Nige, Apr 30, 2011
  11. The Older Gentleman
    YTC#1 Guest
    That will teach him not to use the XT :)
    YTC#1, Apr 30, 2011
  12. You might want to move that chip off your shoulder.
    stephen.packer, Apr 30, 2011
  13. escribió:
    I knocked a door mirror off a cavalier once. That was written off because
    the heated mirror cost more than the car was worth.
    Paul Carmichael, Apr 30, 2011
  14. The Older Gentleman
    On 2011-04-30 07:56:30 +0100, The Older Gentleman said:
    snip>
    It seems to have recovered after WD40 was applied to the coil
    connections but will need further investigation.
    We hopped on a train at Calais rather than endure the 3 hour wait for
    the ferry and ended up getting home just after 4pm.
    Andy Bonwick, May 1, 2011
  15. First pic; on the hard shoulder of the autoroute. Helmet in foreground
    is Colin Irvine, who stopped to render assistance and did sterling
    service in so doing. Thanks, Col.
    Pic 2 is the completed bodge which got us to the hotel, plus the
    Saturday bimble, and then home today.
    http://www.neil_murray.fastmail.fm/Wiringbodge1.jpg
    http://www.neil_murray.fastmail.fm/Wiringbodge2.jpg
    The Older Gentleman, May 1, 2011
  16. The Older Gentleman
    Pete Fisher Guest
    I guessed as much when you didn't appear in the ferry queue or on the
    hard shoulder after you left the services just after Abbeville.
    I used the M40 as usual, though Ogden's news that the M1 was closed near
    Northampton was the clincher. M25 not too bad at all and good progress
    was made. The lack of streamlining on the Shiver seems to have a
    significant effect on fuel consumption beyond a certain cruising speed,
    but the Puig fly screen means I have less of a stiff neck than after the
    run back from Dieppe on the Voxan.
    | Pete Fisher at Home: |
    Pete Fisher, May 1, 2011
  17. The Older Gentleman
    Salad Dodger Guest
    We stayed on N's and D's all the way to J36 ogf the A16, and filled up
    at J11 of the M20.
    188 miles for 18 litres. About 45mpg, not bad into that bloody wind.
    Salad Dodger, May 1, 2011
  18. The Older Gentleman
    Salad Dodger Guest
    According to the SatNav track, we we doing 77mph when it hit.
  19. The Older Gentleman
    antonye Guest
    I set a new record of 71 miles until the fuel light came on ...
    rolling off the ramp at Dover. I know this because I figured out
    how to reset the trip counter!
    antonye, May 1, 2011
  20. BMW was managing about 48-49mpg over the weekend. It's always been
    extraordinarily economical.
    The Older Gentleman, May 2, 2011
