Hi, My 1991 45k miles GSX600F front brake is hopeless. It used to be perfectly adequate but the lever now comes all the way back to the bar. I 'think' it got significantly worse after a high-side crash where the master cylinder got superficially twatted so I assumed I'd shaken some air into the system. I've bled them on two occasions, but cannot find any air in there. Is there a special technique? I've stripped the calipers, cleaned up the pistons and behind the seals, replaced any deformed seals. The pads (?type) are ?5 years old but still have ?4mm left. Surely these are irrelevant though. It still has the original rubber hoses. Are these the only possible explanation? Approx hHow much are new hoses? Anything else I can do to identify the problem? Steve
