It is increasingly difficult to find clear petrol proof plastic tube, braided or not. I need some for the rocker breathers on the SO Morini. B & Q[1] do polythene tube in the right size as Antonye says, but I'm not sure I fancy using it. [1] yes we have them in the frozen midlands. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
I wasn't too sure if it would be proof-enough to do brake fluid, but tbh it would last long enough to bleed the brakes and it's cheap enough to chuck it away and buy another bit next time, especially when you can get 3-4 lengths out of a metre. I did have some clear tube that I used on reservoirs but they started leeching after a week, so had to replace it with some proper black reservoir tube that I got from GPRdirect.com who are Brembo importers. Funnily enough, I was looking at petrol hose the other day as I've put a new tank on the 748 to finally replace the dinged one from a couple of years ago; just in time for the French Run. I had originally swapped a new tank but never got round to fitting it, only to find a couple of weeks ago that the pump mount was warped so it wouldn't hold any fuel. Anyway (getting back on track) I went to measure what size petrol hose I needed for the breathers inside the tank so I could order some off ebay, only to find that there were some in the warped tank that I could put into the new tank and use the dinged one for trackdays. Kinda result. Maybe the lack of clear hose is down to the prevalence of FI systems and the higher pressures that require braided lines?
BTW Pete, 30m for £9 enough to last you? ;-) http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230187191422
In communiqué Hmm, 1/4 ID is a bit skimpy. I could soften the end (ooh mrs) in hot water and force it on, but I wouldn't like to restrict the breathing. In the past I have used the clear pipe with a thready braided appearance, which seems to go brittle with age (I suppose 25 years is asking abit much), or the clear blue/green 'Cavis' stuff which is fairly firm. It needs to be resistant to kinking or squishing. I route it as carefully as I can, but in the rush of paddock fiddling it might get trapped. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
Thank you. £50 sounds acceptable. A quick rummage on Google has found these for £63 + £5 postage. http://www.bsr-aerotek.com/store/product_info.php?products_id=5042 If anyone knows of a cheaper option then that would be useful. Go for 2 long hoses and a double length bolt at the top. The total length of hose is greater (by the length of the normal top section) but it's still cheaper and much easier to bleed and keep air-free as there's nowhere for air to get trapped in the middle.
The hoses I linked to come with all hoses with stainless fittings, stainless banjos and new copper washers, they even have rubber hose protectors on the lines to go into cable clamps. At about 50 quid for three lines you won't find cheaper, and they are a respected brand too. -- Lozzo Suzuki SV650S K5 Honda CBR600 FW trackbike Yamaha SR250 Spazz-Trakka Suzuki GSXR750 L Suzuki TS50X Suzuki TS50X
In communiqué That may well be it. Even my local pikey car parts place could only offer thick walled black hose in various diameters. I may well go with the B&Q stuff. As it is only carrying crankcase fumes rather than fuel supply it isn't too critical. If it starts to degrade I can change it. I don't want anything too large in OD as it has to fit in to the opening in my catch bottle. One inch bore crankcase breather, plus two rocker box breathers in to the same Halfords bike drink bottle I used in 1981. The labyrinth 'arrestors' in all three breathers do a pretty good job anyway. Though when I had a Rope type ring catastrophe once (not diesel in the tank but a bodged rebore) the bottle earned it's keep. -- +----------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest * 2 Yamaha WR250Z | | Gilera GFR * 2 Moto Morini 2C/375 Morini 350 "Forgotten Error" | +----------------------------------------------------------------+
