Front Numberplates are officially dead.
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Oct 13, 2006.
  1. Front Numberplates for motorcycles are gone, taken off the National agenda
    for action. It's over. The ignorant finger of blame has been withdrawn.
    I am pleased to inform you that the National Road Safety
    Action Plan 2007 and 2008 was approved today by the
    Australian Transport Council. Release of the new Plan was
    announced in a joint media statement by Ministers Lloyd and Vaile
    (http://www.ministers.dotars.gov.au/jl/releases/2006/October/L130_2006.htm)
    and the document can be accessed directly
    from the ATC website at the following address:
    http://www.atcouncil.gov.au/documents/nrss_actionplan_0708.pdf.
    The NRSS AP document is about 4Mb to download.
    Riveting reading.
    This particular NRSS AP is the best I have seen. There is evidence of
    open minds and thoughtful inquiry. It is not all agreeable, but much
    more reasonable.
    Reason and common sense have come forward. We need to give recognition
    to this, encourage it, give praise to the NRSS Panel members.
    I am pleased that common sense has prevailed and the silly proposal has
    finally been dropped.
    Guy Stanford
    MCC of NSW
  2. Zebee Johnstone
    WooHoo!
    If Shane's brain ever returns from it's cabbage-like state he'll be very
    disappointed.
    Knobdoodle, Oct 13, 2006
  3. Zebee Johnstone
    conradvr Guest
    But on Page 28 they say
    "Enhance speed limit enforcement through legislative or
    regulatory change to require clear identifi cation of all motor
    vehicles (front and rear number plates or other identifi cation
    technology)."
    And they refer to the study from the Uni in SA that states 5km/hr over
    the limit doubles the crash risk, wasn't this paper found wanting under
    scrutiny?
    conradvr, Oct 13, 2006
  4. Zebee Johnstone
    Kev Guest
    why is there so much opposition to having front plates on a bike?
    Kev
    Kev, Oct 13, 2006
  5. Because with a front plate, speed-cams can get them in both directions.
    Graham Fountain, Oct 13, 2006
  6. Zebee Johnstone
    PHATRS Guest
    Because all motorcyclists will get speeding fines. Proof of my assertion
    is that I have not seen one that doesn't speed. :p
    PHATRS, Oct 13, 2006
  7. In aus.motorcycles on Sat, 14 Oct 2006 06:48:29 +1000
    Because it's not about safety. The amount of money spent on it to date
    is ridiculous (and the amount spent to make it happen if they ever found
    a way to do it ditto).
    Now if that money had been spent on decent road safety for motorcycles
    then maybe there might be an improvement.
    Spend it on this excuse for road safety and there are two results -
    one is that the money is wasted and the other is that the idea that
    road safety is about speed is reinforced.
    Sure, speed can be a factor. But it's not the only factor and with
    all the increased enforcement of same the result has been no
    measurable improvement that can be shown to be caused by the
    enforcement rather than by the other initiatives. (And the other
    initiatives can be shown to have an effect by the changes in crash
    type and timing.)
    After all, as far as motorcycles are concerned the big killers are
    car drivers not keeping due lookout, and the speeds of the majority of
    such cases are under the urban speed limit.
    Zebee
    - leaving the crosspost in, but won't in future.
  8. Zebee Johnstone
    Boxer Guest
    Because they were removed due to safety concerns some 25 years ago.
    Motorcycles are not currently designed to accommodate them.
    The cost to retrofit all motorcycles with front plates outweighs the
    benefits available.
    Many motorcycles can not be fitted with plates safely.
    Traffic enforcement authorities can easily aim cameras at the rear of
    vehicles to avoid the "need" for front plates.
    No other country in the world uses them and therefore requiring them in the
    future would require special models of bikes for Australia only
    significantly increasing the cost of Australian spec motorcycles.
    Boxer
    Boxer, Oct 13, 2006
  9. Zebee Johnstone
    Albm&ctd Guest
    Well if it were on my front guard it would have to be no more than 50mm
    high to not have it embed into the fairing under full fork compression.
    We can only guess at what the next stupid proposal will be. In the quest
    for a perfection they may have to kill us all off after they find the
    perfect citizen that does nothing wrong at all, then clone them.
    OK that's a bit silly but consider a shock collar on all drivers that
    activated when your vehicle exceeded the speed limit for any reason. It
    would work and then nobody would speed but the majority of accidents
    would still happen and maybe even increase when failing to overtake
    safely. The roads, (better roads for Qld) being funded from speeding
    fines would deteriorate even further.
    Back to my motorcycle. There are very few of this make/model the road and
    a picture of it would be easily recognisable. Would they be able to
    supply one picture of my motorcycle avoiding a fine? If not why would I
    have to deface this machine?
    The system is basically corrupt because fines = money to revenue. If it
    were all about road safety they would only have the points system and no
    fine.
    Al
    Albm&ctd, Oct 14, 2006
  10. Zebee Johnstone
    the_dawggie Guest
    Not all. My TT250A dirt bike would have no problems accommodating
    a plate on the large front plastic area around the speedo for example.
    While it might look a little weird at first, I can't really see it as
    dangerous.
    I'm thinking the right way of implementing it which would be ferpectly
    safe and look not at all weird would be a large sticky car rego label
    type thing.
    Of course, correct, this just won't fit every make and model of bike.
    the_dawggie, Oct 14, 2006
  11. Zebee Johnstone
    Toosmoky Guest
    Why don't they just turn all the cameras to point at the back end of a
    vehicle?
    Toosmoky, Oct 14, 2006
  12. Zebee Johnstone
    Michael C Guest
    As a car driver does a bike doing 10 to 20 over the limit really effect you?
    Michael
    Michael C, Oct 14, 2006
  13. Zebee Johnstone
    Albm&ctd Guest
    Call *that* a motorcycle? :)
    Al
  14. Zebee Johnstone
    Uncle Bully Guest
    Something along the lines of if 5km/h doubles the risk then what does 10km/h
    do? Even if the progession is linear you reach some point where speed x is
    guaranteed to kill you.
    Also if 5km/h over doubles the risk, then by the same logic reducing it 5
    km/h will be safer, therefore we should reduce all limits. Except that what
    ever you reduce it to, another 5km/h will be safer again. The logical
    conclusion being that only zero km/h is safe.
    Except that the reality is that some people still die while not moving, and
    others don't die while moving very quickly. So the whole argument is bunk.
    Uncle Bully, Oct 14, 2006
  15. Zebee Johnstone
    Uncle Bully Guest
    No, it just means we have to interupt our already expedient journey for 5
    seconds whenever a forward facing camera is on the road. Why bother with the
    effort and expense when it won't really change anything.
  16. Zebee Johnstone
    Uncle Bully Guest
    Because the Governemnt picks and chooses its definition of 'speed' and
    'speeding' when it suits.
    Driving/riding over the limit, and driving/riding to fast for the conditions
    are two entirely seperate concepts. However the govt bundles both into the
    word speeding, and thinks that using camera to stop the first type of
    speeding will somehow prevent the second type.
    As long as this menatliy is maintained, road safety will always be an issue.
  17. Zebee Johnstone
    Boxer Guest
    My ducat Monster has no front faring of any sort just a headlight, the front
    guard being carbon fibre will not support a mounting bracket.
    Boxer
    Boxer, Oct 14, 2006
  18. Zebee Johnstone
    PHATRS Guest
    No. See 'tongue-in-cheek' smiley above.
    PHATRS, Oct 14, 2006
  19. Zebee Johnstone
    PHATRS Guest
    Bullshit. They don't think that speeding will prevent dangerous driving
    or riding at all. They know plenty of sheep will vote for them if
    they're seen to be doing something about road safety, regardless of the
    impact of speeding fines on the road toll.
  20. Zebee Johnstone
    willsjunk Guest
    thats a subject that cuts right to the bone
    willsjunk, Oct 14, 2006
