Yes, I know, I know... I said the other day I was going to keep it, but I've seen something else at the right money which really appeals. 1998 Yamaha Fazer FZS600 in black. Just under 23k miles from new with a reasonable amount of history to suggest this is correct. Meta remote alarm with two pads. MOT and tax til June 2009. Renthal bars and rack. Stainless Micron downpipes. This week I've been rather benevolent towards it, and have bought and fitted the following to it: Battery Clutch cable Rear brake disc Rear wheel bearings Front sprocket (1) Bridgestone BT021 rear tyre I've also changed the oil and filter and having roadtested it for the first time today, the clutch has developed a slight slip... which is why on the recommendation of the local Yammie dealer, I'm changing the Halfords part synth oil I stupidly put in it for the official Yamaha mineral stuff tomorrow. I've also modded the headlight wiring today (2) so both sides are lit up rather than the more usual one, on dipped beam. And finally, I've given the swingarm a damn good degrease etc, and it all looks rather spiffy now. :-) New plugs a couple of weeks ago or so, and new fork seals a few months back apparently - in other words, given the front tyre is good, it needs nothing. Pretty tidy for the year overall - no pitting to the forks etc, as tends to happen to the more abused Fazers out there, a couple of marks on the tank / side panels, but not out of the ordinary for a bike approaching 11 years old. Dirt cheap to run even if you tend to like riding 'enthusiastically', and the insurance is peanuts considering the performance on offer - not sure I'm doing the right thing selling this to get another behemoth but whatever, I need to finally own one of what it is I'm planning to replace it with or I'll always be wondering 'what if'. :-) 1295 of your finest Engrish pounds, located in Kent, pics available on request. (1) Yes I know, you should always change these as a set, but the last owner was obviously a bit limp wristed and couldn't get the sprocket retainer nut off, so changed the rear sprocket and chain and left this as it was, as I discovered when I removed the sprocket housing to change the clutch cable. (2) Known, well documented mod, this.
