FS soon: Ducati ST4-S 2003
Discussion in 'UK Motorcycles' started by Hog, May 12, 2008.
  1. Hog
    antonye Guest
    It's deffo a dry clutch - I can see that from the pictures.
    The slave cylinder is on the L/H/S of the engine and uses a
    push-rod which goes all the way through the engine to engage
    the clutch. On the wet clutch models the slave cylinder is
    built into the R/H/S clutch casing.
    Dry clutch:
    http://www.blazen.com/mike/monster/SLAVE_1.jpg
    Wet clutch:
    http://www.giovannimoto.com/uploads/20465d6a66e7b64175760779.jpg
    The other give-away is the thick rubber gasket around the
    clutch cover. You can take this out (only 3 of the bolts
    need removing to remove the cover, not all six) and then
    take the spacers out of the rubber gasket and reassemble
    without the rubber. This spaces the clutch cover nicely
    and allows air in and dust out, without a full vented
    cover.
    One tip is to keep the clutch clean (hence the venting)
    but also to keep the clutch pressure plate bearing lubed
    otherwise it can seize and lead to a rotating clutch push
    rod which will then wear either the rod or the engine.
    You only need a drop of 3-in-1 every couple of thousand
    miles, but it's worth doing to prolong the life.
    Also, the ST3 and ST4 have an alloy clutch basket and plates
    which helps to make the clutch action lighter over the
    standard Ducati dry clutch.
    antonye, May 21, 2008
    #61
  2. Hog
    Eddie Guest
    Interesting... does that apply to any Ducati motor with a dry clutch?
    Oh, and how do you know *which* three bolts?
    Eddie, May 21, 2008
    #62
  3. Hog
    antonye Guest
    Yes - in fact it would apply to any dry clutch tbh.
    When the bearing goes you get all sorts of weird symptoms.
    They're less than a fiver to replace and are push-fit, but
    not always the thing that people associate with the problem.
    For example you can get the push-rod spinning so it wears the
    two sealing o-rings that are on it, which leads to oil leaks
    from the slave cylinder side of the engine case. I've seen
    people go through 3 or 4 "dodgy" slave cylinders before they
    figure that one out. In extreme cases it also wear the pushrod
    pathways out, so no amount of replacement o-rings will seal
    them - and that's new cases time. Other effects can be stiff
    clutch levers, squealing sounds, etc, etc.
    If you inspect the cover closely it should be obvious because
    the cover holding bolts are at the level of the cover but the
    others are engine bolts so slightly recessed. I've just checked
    and it's four cover bolts to remove - the engine bolts are
    at 11 o'clock and 8 o'clock, as per this picture which uses
    a later (standard) clutch cover that doesn't expose the two
    engine bolts:
    http://www.milesenglish.com/supersport/images/DSCN0769.jpg
    #63
  4. Hog
    Eddie Guest
    < snip >
    Fantastic, thanks for all that.
    One final question: if you don't *need* the gasket, why do they bother
    fitting one in the first place? Just noise reduction? Both of ours are
    already fairly noisy, so a little bit more clatter won't make much
    difference.
    Eddie, May 21, 2008
    #64
  5. Hog
    Indeed cheers. I knew as soon as it came off the truck. As it was my
    first enquiry when I found it on the web I shall be expecting a few more
    squid back in the account, making it even nicer.
    One day a last revision wet clutch ABS model will come up and it will be
    mine!
    Hog, May 21, 2008
    #65
  6. Hog
    Yes TBF quite a lot of noise but obviously the same as a fancy cut away
    clutch cover.
    One can buy titanium faced clutch baskets with better tolerances which
    don't wear. Allegedly quieter/better. Any experience Ant?
    Hog, May 21, 2008
    #66
  7. Hog
    zymurgy Guest
    My CCM R30 is up for grabs.
    P.
    zymurgy, May 21, 2008
    #67
  8. Hog
    antonye Guest
    Noise reduction and corrosion resistance would be my
    guess. Ducati fasteners are terrible - the 748 once
    developed a beard having used it in (*gasp*) winter
    once and not washing it down before putting it away.
    I replaced my standard springs and fasteners with
    stainless versions before moving onto a slipper
    clutch for good measure. Having said that, the
    Hypermotard appears to have stainless throughout.
    Maybe Ducati have finally twigged that the extra
    few pence is worth the spend.
    If you're getting a *lot* of noise from your clutch,
    check the tolerance between the clutch plate tangs
    and the basket - the Ducati wear limit is 0.6mm which
    isn't very much at all. The clutch will still operate
    fine but it just gets noisier and the basket will get
    more notchy the longer you leave it.
    The standard combination of steel basket and steel
    plates makes a hell of a racket, and they tend to
    wear each other at the same time, so you end up
    replacing a basket and plates - mucho dosh. The
    trick is to use ST alloy plates (as mentioned) because
    these then wear out quicker, rather than the basket,
    so it makes it less expensive next time round.
    You can buy trick titanium faced baskets (as Hog
    mentions below) which will wear less quickly, but
    I think you'd be better off saving your money and
    switching to alloy plates for both wear and the
    lighter action it gives.
    The other thing you can do is to swap to a 48 tooth
    basket, but you would have to replace all the clutch
    pack at the same time. Standard plates are 12T so
    you're basically spreading the load over 4x the
    surface area and should see 4x less wear, IYSWIM.
    However, most of these seem to be alloy baskets and
    steel plates, so probably wouldn't save much in
    comparison anyway!
    Personally I have a 48T STM Evo slipper in the 748
    which is a joy for caning the tits off it. I'm not
    concerned about wear as I was given a load of new
    plates for it ... and it doesn't get used much
    anyway. The 620SS race bike has a wet clutch which
    is a lot less prone to wear than the dry clutches,
    althought the earlier 600SS (583cc) used to burn
    out very quickly as they just weren't designed for
    the abuse we were giving them - an extra plate used
    to help these. The Hypermotard has a standard dry
    clutch in it right now and I'm tempted to leave it
    for the time being until another cheap STM Evo comes
    along - not much chance of that!
    #68
  9. Hog
    antonye Guest
    My mate has one on his 998S Bostrom Rep (that was
    previously on his 996S) but I think it's just bling
    rather than a useful upgrade. His does have replaceable
    faces as well, which I thought was a great idea, but
    I'm sure that by the time he comes to need a new set
    the manufacturer will be long gone off ebay!
    As I said above to Eddie, the best combination is to
    have the alloy plates and steel basket as the plates
    will wear quicker, and they're cheaper to replace.
    If you're that concerned you can go to 48T model baskets,
    which seems to be de facto in slipper clutches, but
    again you really want to be using alloy plates in them
    to reduce overall wear.
    Having said all that, I'm not convinced that Ducatis
    are particularly hard on clutches and have just got
    a lot of bad press because people don't know it's a
    dry clutch and they sound like spanners in a washing
    machine; which is what it should sound like!
    #69
  10. Hog
    antonye Guest
    I saw an 2005 ST4S on the club site; 9k miles, grey, full
    service last summer at Cornerspeed, panniers included for
    4,950 ono.
    Not seen any of the ABS ones come up though!
    #70
  11. Hog
    Eddie Guest
    Okay, now I'm confused.
    The Monster looks exactly as I'd expect: the clutch cover is the same
    shape as the one in the picture, and there's a very obvious geet big
    thick rubber gasket.
    The 'Fant has the same cover, but there's no sign of a gasket, and no
    obvious gap either. Has someone taken out the gasket but not put the
    spacers back in?
    Eddie, May 22, 2008
    #71
  12. Hog
    Eddie Guest
    Shocking. And I wonder why people think my choice of winter hack may not
    be entirely wise...
    I think the Monster clutch is the noisier of the two, and probably worth
    checking, but they're different engines so it's hard to compare them to
    decide if one is worse than the other.
    Eddie, May 22, 2008
    #72
  13. Hog
    antonye Guest
    One way to find out - start removing the cover and if oil comes
    out then do it back up again ;-)
    antonye, May 22, 2008
    #73
  14. Hog
    My 996 (1999) and the ST are the best finished most rot proof bikes I've
    owned.
    Hog, May 22, 2008
    #74
  15. Hog
    Eddie Guest
    Heh. I'm pretty sure it's dry, it certainly feels like it. It seems very
    grabby at low speeds, much more so than the Monster's.
    Eddie, May 22, 2008
    #75
  16. Hog
    Yup there is a 2005 model around now.
    I want the very last 121bhp/ABS/oil clutch model.
    I'd buy a new one FFS.
    Hog, May 22, 2008
    #76
  17. Hog
    nothing wrong with the dry clutches except they rattle like **** sitting
    at lights
    Hog, May 22, 2008
    #77
  18. Hog
    SteveH Guest
    Emailed. If it's still available, that is.
    SteveH, Jun 10, 2008
    #78
