fuel injection vs carbs
Discussion in 'UK Motorcycles' started by Tim, May 10, 2011.
  1. Tim
    Tim Guest
    I was intrigued by a comment about avoiding bikes with FI in the interests
    of reliability. (It's always possible I misinterpreted the comments of
    course).
    It seems to me that in cars at least, the two biggest improvements in car
    reliability have come aout thanks to electronic ignition and fuel
    injection. Does this not apply to bikes or are there some very poor FI
    systems out there?
    Tim
    Tim, May 10, 2011
  2. Tim
    september.org:
    This is your post & Hog's reply
    Things without full fairings then. Parallel/flat twins ideally, or singles.
    Without EFI.
    </q>
    Note the context. He was talking about ease of diy servicing.
    Bike EFI systems are pretty good nowadays and can be tinkered with by those
    with the right software on their laptops.
    Older EFI systems such as the Bosch job on my R-GS are piss easy to
    maintain. Easier than the earlier versions of the bike with carbs I reckon.
    Although, I'm too lazy to do my servicing and GAMI. I've watched him do the
    tweaking and it takes a few minutes with dual pressure gauges.
    wessie, May 10, 2011
  3. Tim
    On the SV forum there's one particular poster who encourages newbies to
    buy the older curvy model because they have reliable carbs not fancy
    and potentially expensively troublesome FI. Chris is a talented young
    mechanic who knows his way round an SV blindfold and gets all manner of
    tech questions thrown at him, which he answers with some bloody good
    advice... except for that one thing.
    A little while ago, just after he'd recommended one of those ultra
    reliable carb models to someone, I pointed out to him that all of his
    tech queries relating to bad fuelling, sticky chokes, knackered
    throttle linkages etc came from carb model owners; no-one with an FI
    bike had ever reported a problem. The earlier carb model was made from
    1999 to 2002 and probably account for less than 25% of the bikes on the
    forum, the FI bikes have been around for 8 years now and the FI is the
    best bit about them - everything else fails or falls off, but never the
    FI system.
    Another thing I pointed out was, if an FI system does ever fail the
    used parts to repair will cost pennies because the supply far outstrips
    demand - no bugger ever needs them. You can't buy good used SV carbs
    anywhere nowadays.
    Lozzo
    they churn out)
    Lozzo, May 11, 2011
  4. There is a reason carbs are going they way of the dinosaur. They are
    shit. : )
    There is a guy on aus.cars at the moment saying how great they are
    because you can fix them yourself. He seems to miss the point that with
    fuel injection you never need to fix it all.
    Fraser
    Fraser Johnston, May 11, 2011
  5. Tim
    Eiron Guest
    Never?
    How many older FI cars have problems with tickover speed and starting?
    How many Vauxhalls and French cars need replacement ECUs?
    Do injectors wear? I don't think any car FI system can adjust fuelling
    to individual injectors so the mixture could vary between cylinders.
    I don't know if that is a problem.
    Eiron, May 11, 2011
  6. Tim
    Adrian Guest
    Oooh... Take the idle valve off, fill it with carb cleaner, and give it a
    shake...
    Hmm. What was the name of that solvent again?
    Wear and get clagged with muck from fuel, yes. But they cost me £50 to
    have a set of four fully ultrasonically cleaned and the wearing parts
    replaced a couple of years ago.
    Adrian, May 11, 2011
  7. Tim
    Eiron Guest
    So that's another vote for 'FI never needs fixing'. :)
    Eiron, May 11, 2011
  8. Tim
    Cab Guest
    Eiron wibbled forthrightly:
    Okay, it's probably wrong to say you never need to fix them. However
    you need to fix them a damn sight less than carbs.
    Cab, May 11, 2011
  9. Tim
    Adrian Guest
    ....after somewhere north of 200k miles...
  10. Tim
    Scraggy Guest
    Fewer, FFS!
    Scraggy, May 11, 2011
  11. Tim
    Hog. Guest
    Thanks to Wessie for clarifying what I said. In the reliability and
    functionality stakes I'll take EFI every time but if it goes wrong I don't
    have AFC how to intervene.
    A single carb is piss easy to maintain OTOH.
    Dual carbs should be easy too but on some bikes are a right caaant to get
    at. Airhead carbs, being large simple CV's with open access are a doddle
    and TBF if you service them every 5 years or so they never miss a beat.
    I know Loz doesn't agree but I think a late Airhead with two simple mods is
    the most reliable and easy to maintain bike you can run.
    Hog., May 11, 2011
  12. Tim
    Hog. Guest
    Does Slic add carbs to any of the modern race bikes? I doubt it somehow.
    I don't know a damn thing about it, which bothers me, but I know there are
    some amazing high flying custom EFI systems out there. With a laptop and a
    Dyno (and a programmed brain) I expect the results are pretty amazing.
    Hog., May 11, 2011
  13. Tim
    Engine wise, maybe. But what about when the starter motor or clutch
    need replacing?
    Krusty, May 11, 2011
  14. Tim
    Hog. Guest
    Every bike needs servicing.
    Starter motors? what, once every 100k miles. At 50 take it out and service
    the mechanism. It's a doddle to get at.
    Clutch? again 100k unless you are cack handed and frankly it's real quick &
    easy, when you know how and you have a little customized spanners and a
    centering tool.
    Almost all the (late) Airhead failures are down to a lack of servicing.
    Starters, clutches, carbs and valves. It's so fucking easy to work on there
    is no excuse. There is a reason you can't find used 1000cc engines, people
    snap them up for light aeroplanes, which says loads.
    The only two GAMI jobs are:
    replacing mains, which is down to lack of oil changes or low oil or wrong
    oil
    gearbox rebuilds, for same reasons
    Rebuilding the gearbox is actually a doddle but you have to shim the end
    float just right.
    Hog., May 11, 2011
  15. A well tuned FI system is thew way forward end of. However there are
    still some dodgy bike systems out there still. Well when I say some, I
    mean the FI on the 990 KTM Adventure's from 2006 - 2008 (haven't
    ridden a later one - apparently they are "better" but still not
    great). My '06 Adv was a nightmare "just off closed throttle" and off
    road was a liability. Got to the point that I traded it for a 950
    SuperEnduro because a) I always fancied one, and b) it had carbs which
    I've adjusted to suit the bike / my riding[1]. The Adv forums are
    always one about trying to tune the FI - if they get it right (and I
    mean Tuono / '05 Gixr1000 right) I'd have another, but not until then.
    cheers
    SS
    [1] still "snap, crackles and pops" on the over run, but I quite like
    it......[2]
    [2] I'm sure a GOOD FI system would be better but it's not available
    on them
    Spinning Spanners, May 11, 2011
  16. Tim
    Tim Downie Guest
    Hmm, a friend has offered to sell me his old R100RT (in need of some
    restoration work). Shoud I bite?
    Tim
    Tim Downie, May 11, 2011
  17. Tim
    TOG@Toil Guest
    Depends on what needs doing. A lot of BMW spares are surprisingly
    cheap. But c(for example) replacing a clutch is a bugger as the bike
    is basically built around it, and gearbox work can be very expensive.
    TOG@Toil, May 11, 2011
  18. Well as TOG says a) depends on what needs doing, b) how much he wants
    for it , and c) are you handy with the spanners to do it yourself, or
    will you need to pay someone?
    Also is that really the sort of first bike you want? If it's dead
    cheap and doesn't need much doing then it's cheap to drop the few
    times you might over the first year or so, where as a "new and shiney"
    will break your heart if/when you drop it.
    cheers
    SS
  19. Tim
    Jim Guest
    Bit heavy and expensive to repair for a first big bike, I'd say.
    Jim, May 11, 2011
  20. Tim
    Hog. Guest
    If it's a late Mono then it is worth considering. Earlier models are for
    Collectors.
    Spot earlier models by twin shocks
    Hog., May 11, 2011
