Fuel injection's great...
Discussion in 'UK Motorcycles' started by Eddie, Nov 14, 2008.
  1. Eddie
    Eddie Guest
    .... when it works. It's a PITA when it misbehaves.
    The Monster's had some "issues": difficulty starting[0], and a tendency
    to stall from idle.
    Our friendly local mechanic attached his fancy box-o'-tricks to it, and
    it showed that there was some unexpected resistance on a couple of the
    sensors (one being the throttle position sensor, can't remember the
    other). He suspected that the cause was some corrosion in the connectors.
    After having a look last night, it seems that he was right about the
    corrosion. The TPS is tucked up underneath the tank and airbox,
    somewhere behind the frame and a collection of coolant hoses, but using
    the same mechanical gynaecology skills that I used to use when replacing
    cam-chain tensioners on old air-cooled Kwaks I managed to separate the
    connector and see the corrosion on the contacts.
    I tried cleaning them as best I could with some contact cleaner and one
    of those tiny toothbrushes, but it wasn't really helping.
    What's the recommended way of cleaning these things? Obviously, angle
    grinder would be the ideal solution, but there's not really room to get
    it in.
    Once it's clean, I want to pack the connector with grease to stop it
    happening again. What kind of grease is safe to use?
    [0] It's got one of those "self-starter" systems: you press and release
    the starter button, and it's meant to sort itself out from there. Hah.
    Eddie, Nov 14, 2008
  2. Eddie
    JB Guest
    A small brass or fibreglass 'pencil-brush' used for cleaning electronic pcbs
    is best to clean the connectors. Then use silicone grease to prevent further
    corrosion.
    JB
    JB, Nov 14, 2008
  3. Eddie
    RPM sensor?
    Never buy a bike smarter than you are.
    platypus, Nov 14, 2008
  4. Eddie
    antonye Guest
    TPS; it's always the TPS. If your tame mechanic can't
    reset it to the correct setting (might need a friendly
    Ducati service centre for this) then it'll need replacing.
    antonye, Nov 14, 2008
  5. Eddie
    Colin Irvine Guest
    Perhaps fine emery paper or wire wool (if you can be sure not to leave
    any behind).
    If it's metal to metal conductivity you want, petroleum jelly - e.g.
    Vaseline.
    Colin Irvine, Nov 14, 2008
  6. Eddie
    Beav Guest
    Or even better than silicunt grease, use ACF 50.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 14, 2008
  7. Eddie
    Eddie Guest
    Okay, I'll have a look for one, and hope that it's small enough to get
    at the connector on the TPS.
    That's what I thought.
    Eddie, Nov 14, 2008
  8. Eddie
    Eddie Guest
    I'm sure he could reset it, but if there's corrosion on the connector
    it's not going to make any difference, is it?
    Eddie, Nov 14, 2008
  9. Eddie
    Eddie Guest
    Nah, I think the one he pointed at looks like the coolant temperature
    sensor.
    Eh? I'll have to declare myself whooshed.
    Water soluble, isn't it? That wouldn't last long; you'd have to re-apply
    it every time you wanted a ride.
    How smart do you have to be to hold down the starter button yourself?
    Eddie, Nov 14, 2008
  10. Eddie
    Eddie Guest
    I vaguely remember something suggesting that that would be a bad idea.
    Ah, but you don't want conductivity *between* the terminals. That would
    be A Bad Thing. The grease is to provide a better seal around the
    connector, preventing water ingress.
    Eddie, Nov 14, 2008
  11. Pretty much what you're doing is the way to go. You can't get too
    physical with them and if they're too badly corroded to clean up
    properly, it's a question of replacement - preferably with something
    cheap and effective, but room is the issue on a bike, especially under
    the tank.
    Silicone grease /spray.
    Grimly Curmudgeon, Nov 14, 2008
  12. Vaseline isn't conductive.
  13. Eddie
  14. Eddie
    Pete Fisher Guest
    Aha. When the Morini Riders Club Chairman had trouble with his Corsaro
    1200 at the 2007 Manx his Ferrari type starter system wouldn't even
    operate. In the end we put it in gear and rocked it. Hey presto!
    Crankshaft position sensor or possibly neutral indicator we reckon.
    At the 2008 TT it just was an absolute pig to start sometimes. If he
    didn't catch it as it first coughed it wouldn't play. Not an easy feat
    with the delayed action starter.
    He claims an updated ECU has sorted it.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 14, 2008
  15. Eddie
    I like their warning "A certain amount of fibreglass dust is produced
    which should be removed with great care. Avoid touching with exposed
    skin as the particles can easily penetrate flesh and be extremely
    uncomfortable." I used to use these for erasing mistakes on hand-drawn
    graphs prepared for conversion to OHP film[1]. For years I still had a
    little red mark on the edge of my hand where bits of FG had penetrated
    as I'd wipe it off the sheet I was aorking on. Just checked and it's
    not there now, but I don't know how ling it stayed there.
    [1] This was a 4-stage process, IIRC, with lots of chemicals and stuff
    involved in the 'repro shop'.
    _______
    Ace, Nov 14, 2008
  16. Eddie
    Colin Irvine Guest
    Really? A quick google suggests you're right. I was thinking back to
    when I installed telephone exchanges, and the busbars were joined by
    coating the mating surfaces with vaseline and scrubbing with a wire
    brush before bolting them together.
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    But - in the right circumstances - it can be conducive.
    Wicked Uncle Nigel, Nov 14, 2008
  18. Eddie
    Eddie Guest
    Eddie, Nov 14, 2008
  19. Eddie
    Eddie Guest
    The only way to replace the connector on the sensor side would be to buy
    a whole new sensor. No wucking fay.
    Eddie, Nov 14, 2008
  20. Eddie
    TOG@Toil Guest
    I've had *loads* of bikes with this feature....
    TOG@Toil, Nov 14, 2008
