Help needed on me trusty FZ600 Tax is out next week, also got a VFR lined up so I need to fix ASAP Lost the charging system a while back. Symptoms:- voltage across battery terminals does not rise as engine rpm increases, eventually flat battery, no fun bumping it off after you have stalled in a queue of traffic. So far I have: Topped up battery, fluid levels were low Checked fuses Checked and cleaned all terminals and block connectors Checked earth continuity Checked relevant cabling continuity Renewed field brushes Renewed voltage regulator unit Renewed generator rotor Renewed generator stator Sworn lots Meter shows 0.2V AC output on each phase of the generator I would of expected to have seen 50V which points towards the generator, the replacements were from a scrap yard so there could be a question mark over them I suppose. Ok guys, this is doing me nut in, any help gladly accepted.
