Is there a problem with the collective "G" drive? I can log on, can't see anything, and can't see the directory I created? I'd appreciate an objective view on the problem. Also, can I post .75 Gb on the drive for a short period? Taa. -- Greybeard FLHTCUI UK-07 96 cu-in (Written off after 3 days & 182 miles!) Courtesy of a myopic female driver. FLHTCUI UK-07 Mk II Trumpet Trophy 1200 -96, (The Barge) for rainy days. Garmin Zumo 550, To get me home! ukrm@foxtails[dot]co[dot]uk
I had to upgrade to the new 'driver'. I couldn't login with the old version. All seems ok though with all various directoris visible and downloadable. Cheers, JB
Yep found that. I've put the new driver on the GMail drive now as well. Any idea of the maximum size single file I can stuff on the drive for a short time? Cheers. -- Greybeard FLHTCUI UK-07 96 cu-in (Written off after 3 days & 182 miles!) Courtesy of a myopic female driver. FLHTCUI UK-07 Mk II Trumpet Trophy 1200 -96, (The Barge) for rainy days. Garmin Zumo 550, To get me home! ukrm@foxtails[dot]co[dot]uk
Greybeard banged the rocks together and they said : This is a driver required to access the GMail drive, yes? And you've put it on the GMail drive. So people need to access the drive to download the driver so they can access the drive to download the driver so they can access the drive to download the driver so they can access the drive to download the driver so they can access the drive to download the driver so they can access the drive... <Brain GPF Error. Abort, Retry or Cancel?>
http://www.viksoe.dk/code/gmail.htm -- XJ900 Trike ** GS850 Trike XV1000 TR1 Chop ** XLH1200 Sporty Chop [Rot 13 it]
Actually Frag although I see where you are coming from, the original file was already there, I just updated it. It's probably there as easy access for people to email the file to other users should they want it rather than having to hunt the interweb. At least, that's what I've convinced myself, trying to stave off a senior moment ;o) -- Greybeard FLHTCUI UK-07 96 cu-in (Written off after 3 days & 182 miles!) Courtesy of a myopic female driver. FLHTCUI UK-07 Mk II Trumpet Trophy 1200 -96, (The Barge) for rainy days. Garmin Zumo 550, To get me home! ukrm@foxtails[dot]co[dot]uk
Yes, if you want to see it as a "drive" on your machine. No, you can still get in through the web interface using the secret username/password combo. You can still download the files through this web interface and that includes the driver. In fact, you don't need the driver at all to access the same files; the driver just makes it all a bit easier.
square it -- Greybeard FLHTCUI UK-07 96 cu-in (Written off after 3 days & 182 miles!) Courtesy of a myopic female driver. FLHTCUI UK-07 Mk II Trumpet Trophy 1200 -96, (The Barge) for rainy days. Garmin Zumo 550, To get me home! ukrm@foxtails[dot]co[dot]uk
