Garage door - fridge-light style switch?
Discussion in 'UK Motorcycles' started by Jeremy, Jan 29, 2006.
  1. Jeremy
    Jeremy Guest
    I have a door from utility room into my garage (in which my bike resides
    - to keep this on-topic). The garage has a couple of fluorescent tubes
    operated by a regular switch on the wall. The door opens "into" the
    garage.
    I am an impatient sod - when I flick the light switches, I want instant
    illumination but with the tubes, there is a delay while they flicker
    into life.
    It struck me that it'd be really rather nice if I could rig up another
    light which would be automatically switched on/off as the door is
    opened/closed. And as I keep my beer in there in winter it really is a
    fridge, isn't it...
    Anyone got anything similar (no, not the fridge) or do I just head off
    to Maplin and browse the swicthes there? It could be as simple as a
    switch mounted above the door with a lever that is tripped by the top
    edge of the door.
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
  2. Jeremy
    muddy Guest
    Change the ballasts to the electronic type. You get instant on then.
    muddy, Jan 29, 2006
  3. Jeremy
    R obbo Guest
    Ikea used to make door switches on some of their products.
    Although you might consider something like
    http://cgi.ebay.co.uk/New-PIR-Globe...ryZ94941QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    which will give you the necessary illumination until the main lighting kicks
    in
    R obbo, Jan 29, 2006
  4. Jeremy wrote
    Slicker to get a burglar alarm type magnetic switch (to operate a relay
    to turn on the mains) and screw a magnet on the door.
    Or, keeping with the burglar alarm theme: one of them motion sensor
    devices what is designed to turn on the mains driven infra red lights so
    you can film the scrotes. All the technology you need in one box that
    is.
    steve auvache, Jan 29, 2006
  5. Jeremy
    JB Guest
    Measure the length of the tubes and i'll get you some electronice ballasts
    FOC.
    JB
    JB, Jan 29, 2006
  6. Jeremy
    Jeremy Guest
    Thanks - I'll take a look later.
    jeremy
  7. Jeremy
    You can get a PIR activated floodlight for under a tenner - should do
    the job nicely. I've just stuck one in my garage as it happens, giving
    me a total of four PIR activated devices in there. If you can't catch
    the fuckers, irradiate them.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '96 Tiger '79 Fantic 250
    Krusty, Jan 29, 2006
  8. The message <>
    Magnetically-operated reed switch which you let into the upright, and
    the magnet into the door. Will need to activate a relay, as AC mains
    would probably just arc across the gap when it breaks.
    Obtainable from any burglar-alarm stockist. (and Maplin)
    Rusty Hinge 2, Jan 29, 2006
  9. Reed switch in the door frame triggering a DIN mounted relay in a small
    mounting box.
    Or, **** all that, just get a single PIR and use it to switch on a 100
    watt bulb.
    Grimly Curmudgeon, Jan 29, 2006
  10. Jeremy wrote :
    In my garage I have a PIR operated flourescent fitting, one of the
    eight in there. As PIR units by themselves are rather expensive, I used
    one removed from a PIR halogen flood light.
    Open the main front door or the side entrance and the light comes on
    after a small delay, assuming the garage is in darkness. It saved me
    some wiring, plus the light goes out if the door is left open garage
    unoccupied. Walk/drive in and it goes back on. No need to put up with
    the delay, if you use a fitting with an electronic ballast, or you
    could use a bulb instead.
    Harry Bloomfield, Jan 29, 2006
  11. Jeremy
    Leo Guest
    Move the light switch from inside the garage to the near end of the
    utility room.
    Flick the switch as you go past, and by the time you've got the door
    open the light'll be on.
    Leo, Jan 29, 2006
  12. Jeremy
    Christofire Guest
    Could you use mains-driven UV lights to make it hard to see[1] and give
    them a sun-tan to help with the identification?
    [1] When I've looked at UV lights they seem to be bright without being
    bright, IYSWIM. Enough of them would make it very hard to see if
    you're used to a very dark room.
    Christofire, Jan 30, 2006
  13. Jeremy
    Bits of spring-loaded 2x4 covered in nails & mounted at head height
    have a similar effect, albeit a tad more permanent.
    Krusty.
    Krusty, Jan 30, 2006
  14. Jeremy
    Jeremy Guest
    <g>
    jeremy
    Jeremy, Jan 30, 2006
  15. The message <>
    How would very bright UV lights show you if he was used to a very dark room?
    Rusty Hinge 2, Jan 30, 2006
  16. Spikes in the bottom of the inspection pit, and a cover of cardboard?
  17. Jeremy
    Christofire Guest
    Not quite getting your banter, old chap. The point is exactly the
    opposite.
    UV lights make your iris contract, like a properly visible light source
    would. Thus, it makes it "feel" like there's a bright light in front
    of you (i.e. makes you squint), even though you can't see the light as
    it's UV.
    Matey, who's snuck into the dark garage, sets off the PIR which turns
    on the UV light array. His eyes are used to the dark, so he'll find a
    certain amount of discomfort of unknown source when the UV hits him.
    This would only work if there's no UV-reactive things knocking about in
    the garage, as that would provide enough normal light to illuminate the
    room.
  18. The message <>
    Oh dear. Whoosh!
  19. Jeremy
    Christofire Guest
    Well, what do you expect if you're going to be so obtuse?
    Christofire, Jan 31, 2006
  20. The message <>
    Me?
    Or do you mean abstruse?
    Rusty Hinge 2, Jan 31, 2006
