Garage Night new video: Suspension overhaul starts with Dremel on alathe
Discussion in 'Australian Motorcycles' started by Waz, Feb 10, 2010.
  1. Waz
    Stephen! Guest
    Heh... an' I thought depleted uranium was dense... Then along comes
    "George".
    Stephen!, Feb 12, 2010
    #61
  2. actually I learned by DOING and by making jewelry...before stainless
    adn Ti became common. 8^) Unless it's for aviation or the inside of a
    motor it is not that hard to get your metals hard enough...you don't
    need it perfect.
    So, you would be prepared to put in a shaft which was only half tempered,
    allowing for a possible snap in half while you are doing 100kph??
    More laziness than brains
    George W Frost, Feb 12, 2010
    #62
  3. Oh? Plan on putting on the wellies and making a mess of it all?
    See Waz.....? told you there would be more
    You can always count on the dreaded s'mee
    #63
  4. Waz
    Twibil Guest
    Pot. Kettle. Inside of black cat at midnight in a coal mine.
    Twibil, Feb 12, 2010
    #64
  5. Fulliautomatix, Feb 12, 2010
    #65
  6. George W Frost, Feb 12, 2010
    #66
  7. Pot. Kettle. Inside of black cat at midnight in a coal mine.
    Not so sure about a black cat
    but I have been inside a pussy at midnight
    #67
  8. Waz
    F Murtz Guest
    Is not the discussion about a spacer washer? where did the shaft come from
    F Murtz, Feb 12, 2010
    #68
  9. Waz
    F Murtz Guest
    Seems to be hard on thumbs.
    #69
  10. Sorry, but the discussion started with a video of someone cutting a small
    hardened steel shaft from a Ducati to fit into an Elefant swinging arm:
    His quote "deeply scored the hardened steel bush/spacer/shaft that runs
    through them. And being from Cagiva, this part is unobtanium "
    Not sure where the mention of a washer came in, but with some of the
    replies, I can understand your confusion.
    #70
  11. Waz
    Marty H Guest
    they aren't washers...they are dish rags
    mh
    (not that there is anything wrong with that)
    Marty H, Feb 12, 2010
    #71
  12. Waz
    F Murtz Guest
    Ok, Teach me to watch videos in future.(I don't always.)
    #72
  13. Waz
    S'mee Guest
    hmm, your lack of reading comprehension skills is very telling.
    Bragging I see.
    S'mee, Feb 12, 2010
    #73
  14. Waz
    S'mee Guest
    Just don't ask him to read and comprehend what he's read.
    S'mee, Feb 12, 2010
    #74
  15. Waz
    S'mee Guest
    only by fools and idiots. I don't consider you the latter.
    S'mee, Feb 12, 2010
    #75
  16. Hahahahahahaha.
    stephen.packer, Feb 12, 2010
    #76
  17. Waz
    Stephen! Guest
    Seems to me like you ain't had pussy since pussy had you.
    Stephen!, Feb 13, 2010
    #77
  18. Waz
    Bastard! Utter, utter bastard!
    (See you at the Unaugural?)
    BT Humble, Feb 13, 2010
    #78
  19. Waz
    S'mee Guest
    heh and you obviously are an expert at breathing out your ass if the
    pussy is sloppy enought to fit a 4x sized head.
    S'mee, Feb 13, 2010
    #79
  20. Waz
    S'mee Guest
    oww...No need to be that rough.
    S'mee, Feb 13, 2010
    #80
