Gas tank repair
Discussion in 'Motorcycle Technical Discussion' started by Ian Singer, Oct 1, 2006.
  1. Ian Singer
    Ian Singer Guest
    My local automotive store suggested a hole or split in a gas tank can be
    repaired but using a propane torch and lead based solder with flux. Is
    that a viable option? He also suggested first flushing tank with water
    and then methyl hydrate to dry it, to get rid if any fumes. Is that
    necessary as its just ben water flushed.
    Ian Singer
    See my homepage at http://www.iansinger.com
    hosted on http://www.1and1.com/?k_id=10623894
    All genealogy is stored in TMG from http://www.whollygenes.com
    Charts and searching using TNG from http://www.tngsitebuilding.com
    I am near Toronto Canada, can I tell where you are from your reply?
  2. Ian Singer
    durtdog Guest
    Never ever weld (braze, solder etc) on a tank in the open. It doesn't matter
    how old the tank is, or how long it's been empty or 'airing out'. The fumes
    are there and flammable. There is a purging process where you can run steam
    through the talk for a long period of time to get the gas fumes out, then
    it's safe to weld. Some other options are run nitrogen through the tank, or
    immerse the tank in water, except the part you're working on. I read / hear
    about people all the time messing with their tanks and ending up hurt or
    worse. I just brazed a crack in my tank and it worked great.
    durtdog, Oct 1, 2006
  3. Drain tank. Let dry. Open or remove filler cap. Stick car exhaust
    through filler hole (maybe just ram the tank on the end of the car
    exhaust pipe). Run car engine for 15 minutes. Just wave a naked flame
    round the filler orifice. There will be a very small "pop". Yes,
    seriously. Job done.
    The Older Gentleman, Oct 1, 2006
  4. Ian Singer
    B-12 Guest
    Yes. I was trying to braze a split in a Yamaha gas tank that was filled
    with water and there were still fumes. Even though I ran the torch over
    the filler hole, there were *still* fumes trapped in the forward part
    of the tank. My torch ignited them, there was a *bang*! and the tank
    was split worse than it started.
    First gas tank I ever needed to have welded was off an MD-10 ground
    power generator. I was a mechanic, so I took it to the welding shop.
    They said, "No dice. Take it to the paint shop and have the area
    de-painted."
    So I took it to the paint shop to have the weld area de-painted and
    returned to the welding shop. The weldor said, "This thing had gasoline
    in it? Take it to the jet engine shop and have it steam cleaned inside
    for 20 minutes."
    So I took it to the jet engine shop and we steam cleaned it for half an
    hour. Then I dragged the 40 gallon tank back to the welding shop where
    I finally got it welded.
    Guess what I had to do after having the tank welded? Yes, it was back
    to the paint shop to be painted Caterpillar Yellow. And I had to wait
    for hours and hours for the pain to dty before I could handle the tank.
    What a hassle, just to repair a pin hole leak that was weeping. JB Weld
    had not yet been invented. Nobody had ever heard of epoxy...
    My most recent gas tank repairs were done with JB Weld. It's a two part
    epoxy that is dark grey when properly mixed. You degrease the area to
    be patched, roughen it with sandpaper, and apply the JB Weld.
    It cures in about 16 hours and will hold gasoline forever.
    B-12, Oct 1, 2006
  5. Fantastic stuff. I've repaired exhausts with it.
  6. Ian Singer
    durtdog Guest
    Hillbilly nitrogen flush? LOL
    durtdog, Oct 2, 2006
  7. I like that expression. Yes.
    CO2, and lots of it. Nice and inert.
    The Older Gentleman, Oct 2, 2006
  8. I fixed a rock-created hole in a crankcase with the stuff and it's still
    holding after 10+ years.
    Larry Blanchard, Oct 2, 2006
  9. Ian Singer
    Charlie Gary Guest
    I've read the replies to date, and now I recount the experience of the
    only person I ever personally knew who tried such a thing. He was
    soldering a handle back onto a gas can. Empty can. Thought it was
    purged. One final pass with the torch, he thought. It exploded. He
    spent the next three months in the burn ward.
    Some say it's safe. Some do not. I personally would seek a solution
    that didn't involve flames.
    Later,
    Charlie
    Charlie Gary, Oct 2, 2006
  10. Ian Singer
    durtdog Guest
    CO yeah, inert yeah, but I wouldn't do it simply due to the fact that
    welding on gas tanks is dangerous enough not to mention hanging around
    deadly fumes. To each his own!
    cheers
    durtdog, Oct 3, 2006
  11. CO2 or petrol vapour?
    The Older Gentleman, Oct 3, 2006
  12. Ian Singer
    LJ Guest
    JB Weld. It'll hold as long as you own the bike and it will cost less than
    $10. The only downside is that it will degrade if you put fuel stabilizer
    in the tank and you'll probably have to repatch it. For $10 you will get
    enough epoxy to patch 30 or 40 fuel tanks.
    LJ, Oct 4, 2006
