gasket goodness
Discussion in 'Motorcycle Technical Discussion' started by jseely13, Sep 8, 2004.
  1. jseely13
    jseely13 Guest
    ok, so i've got this oil leaking from a couple of gaskets on my
    75kz400, which gets on hot parts of the engine/exhaust and makes my
    bike a smoke generator. i got a gasket set on ebay a few years back,
    so i'm thinking about trying to solve my problem.
    the issue i have is how far to take this whole process. the clutch
    cover gasket will be simple. the main leaks seem to be coming from a
    bolt under the spark plugs... the cylinder head gasket i think. if i
    get the cylinder head off, i figure i can replace that gasket and the
    oil passage o-rings and such, but then what? do i keep taking the
    engine apart to replace gaskets, piston rings, etc further down so i
    don't have to take it apart again later, or do i leave well enough
    alone and put it back together replacing only the stuff i think i need
    to?
    thanks,
    -- john
  2. jseely13
    Charlie Gary Guest
    If it ain't broke.........................
    Charlie Gary, Sep 8, 2004
  3. jseely13
    Mark Olson Guest
    Oil leaking near the cylinder head gasket is probably not due to a
    faulty gasket. More likely, the o-rings that seal the oil passages
    between the cylinder block and the head have hardened or deteriorated.
    In any case, when reassembling the head to the cylinder, you should
    use a new head gasket.
    If you don't pull the cylinder off the cases, and it doesn't come
    loose on its own, I'd leave well enough alone.
    Mark Olson, Sep 9, 2004
  4. I agree. I'm not as familiar with Kawasakis, but I had a '76 Honda
    CB750F that did just exactly this. I ordered an upper end gasket set
    from my local dealer, then decided to also have them do the work. The
    results were excellent!
    Yes, life's too short to reuse gaskets. ;-)
    Yes, but you should pull the cylinders while you have the engine that
    much apart so as to properly inspect them, especially if the base gasket
    is included in the set.
    Michael R. Kesti, Sep 9, 2004
  5. jseely13
    Mark Olson Guest
    You don't have to remove the cylinders to inspect the bores. You may
    wish to get a look at the pistons and rings, but unless you have reason
    to suspect there is a problem with the rings (excessive oil burning or
    low compression) or think that there is another O-ring problem at the
    base of the cylinders, I will stick with my recommendation.
    When I replaced some valves in the CM400T, I agonized over whether to
    remove the cylinders. I finally decided to go ahead, even though
    compression was OK-ish, and the bores looked perfect, but I gave it
    up when I had pounded and pried the crap out of it and it hadn't
    budged loose. I suppose I could have worked on it for another day or
    so and eventually busted it loose. It does burn a little oil, which
    after replacing the valve seals, I am sure is down to the oil rings,
    but not enough to notice any smoke.
    I'm still not sure why the cylinder block was so firmly wedded to the
    engine cases.
  6. Agreed.
    The Older Gentleman, Sep 9, 2004
  7. jseely13
    jseely13 Guest
    you guys kick ass... thanks!
    -- john
    jseely13, Sep 9, 2004
  8. jseely13
    John Johnson Guest
    A question of clarification:
    do you mean the cylinnder head gasket (head gasket, separates the
    cylinder tops from the barrels), or the valve cover gasket (cam-cover
    gasket, covers the valve-gear and is removed when checking valve
    clearances)?
    Typically the valve-cover gasket has molded into it, or goes over, a set
    of half-circle rubber plugs (that fill holes left when boring the
    bearing surfaces for the cams-I'm assuming this is an OHC engine).
    It's not a big deal to replace the valve-cover gasket. It's not unusual
    for such a gasket to leak some oil. It is a big deal if your head gasket
    is leaking oil, and it's much more work to replace that one.
    HTH.
    Later.
    'indiana' is a noun. Leave only the noun and .edu after the @ to reply
    Pismo: 2000-2004 RIP
    15" AlBook: 2004-The PowerBook is dead! Long live the PowerBook!
    John Johnson, Sep 9, 2004
