Gaskets
Discussion in 'Classic Motorbikes' started by Trev, Oct 31, 2003.
  1. Trev
    Trev Guest
    Heyup
    Got a bit of leakage from the oil pan on me GS500 just an annoying drip
    really ;-) Anyone recommend a good make of gasket? i.e. rice cispies or
    cornflakes which is the better? or should I stop being cheap and go to Mr
    Suzuki? Any one know if you need to get the zorst pipes of first?
    Ta
    Trev
    Trev, Oct 31, 2003
  2. Trev
    RG Guest
    Nahthen,
    Compared to further far more informed recommendations I'm sure you will get,
    I have to get in and mention my silicone silliness.
    Ever since successfully using simple bathroom silicone for the primary drive
    cover on the Thunderbird, I've used it elsewhere including for the oil drain
    and filter cover. 500 miles later all is still dry and intact and before TOG
    and Timo ask - yes, the oil is still there.
    Thin, neat bead in place, assemble loosely, then tighten up and compress
    when it's gone off. Easy enough even for me.
    The stuff is dirt cheap, easy to remove. Avoid over doing it so excess can't
    wander off and block anything and remember that petrol contact is a no no.
    Don't know about the zorsty bit.
    Roger
    RG, Oct 31, 2003
  3. Trev
    Trev Guest
    forgot about using the old window sealer
    Ta
    must find a sig
    Trev
    Trev, Oct 31, 2003
