Gears and timing chain
Discussion in 'Australian Motorcycles' started by Gary Smith, Mar 22, 2005.
  1. Gary Smith
    Gary Smith Guest
    Me again, well, this old XLX 250 i bought has started not selecting 2nd gear
    properly. Today i pulled the clutch in and lifted the shifter by hand whilst
    stationary and it pulsed up and down a bit until i pulled that hard it went
    into gear. Sometimes it takes a while to get it into 2nd when riding, from
    2nd up it's ok. just from 1st to 2nd is a problem. last night i put it in
    gear, pulled the clutch in to roll it foreward and it was as though the
    clutch wasn't even working. That was with motor off. when the motor is going
    it seems to work ok with a slight pulse foreward when motor is running , in
    gear, clutch in. I first noticed it after riding for a day or so going from
    1st to second it was going to neutral then getting harder and harder to get
    into 2nd. I try and take off from second now.
    Other question is about timing chain adjustment, cant seem to find the
    adjuster for it.has a chrome bolt thing on the right top rear of the head. I
    presume this is the bolt that holds the top of the tensioner there. I was
    informed from previou posts that this is an XR250re motor. Any input
    appreciated.
    Thanks
    Gary
  2. In aus.motorcycles on Tue, 22 Mar 2005 08:23:53 GMT
    IF it was a Guzzi, I'd say "so adjust the lever arm at the gearbox" but
    I dunno what XL-whatsits do instead.
    Sounds to me like the clutch needs looking at.
    Zebee
    Zebee Johnstone, Mar 22, 2005
  3. Gary Smith
    sharkey Guest
    Clutch is dragging. Adjust it. Gearbox problem will probably go away.
    Buy that Haynes book I mentioned, okay?
    It'll be automatic, although if it's thrashing around like a mad
    thing it could be that the automatic thingo is at the end of its
    life. Did you check which engine it is as per my earlier
    post? Let us know ...
    -----sharks
    sharkey, Mar 22, 2005
  4. Gary Smith
    Gary Smith Guest
    Clutch cable is at its MAX on the handlebars, no adjustment on the motor
    casing.
    Sorry mate, yes it is a 4 valve RFVC motor. I can take pics and mail off
    list if that helps.
    As far as the manual goes, i asked 2 motorbike shops (one was Laurrie Fox
    Honda in mount gambier s.a.) and they said they would get back to me IF they
    could find something. I'm still impatiently waiting for them. If you know
    where i can get a *Haynes* from i'd be glad to get one.
    Thanks again....
    Gary
    Gary Smith, Mar 23, 2005
  5. Gary Smith
    Gary Smith Guest
    Is there an internal adjustment?
    gary
  6. Gary Smith
    GB Guest
    Fark (as in "my forehead how has 'ertyui' indented
    in it in a kind of reverse thing...).
    Change the bloody cable already. (Or buy some new
    walking shoes. Your choice).
    GB, even *I* can see...
    GB, Mar 23, 2005
  7. Gary Smith
    sharkey Guest
    Ummm. No adjustment on the other end of the cable either, like
    two nuts [shaddup Clem] holding it to a bracket?
    And just to check, the adjuster is pulling the clutch *in* as far
    as possible, right? Unusual, because normally clutch plates
    wear *thinner*, and the clutch needs to be adjusted *out* in order
    to fully engage. Perhaps your adjuster is right *out*!
    If the oil isn't new, change it. Shitty oil does terrible things
    to motorcycle gearboxes and clutches. If the oil is really shit,
    change it, ride 100km or so and change it again. I have no idea
    what the RFVC uses for an oil filter, but if you can, change it
    too.
    If there is no adjustment point at which the clutch neither slips
    when engaged nor drags when disengaged (WITH CLEAN OIL), either
    the plates are worn out or the clutch springs are shagged (or
    something else is buggered, I suppose, but those two are the
    normal ones)
    Might be interesting! I don't know all that much about the RFVC
    one, mostly the one before it (4-valve SOHC) but I think they're
    pretty similar below the barrels. I might be wrong.
    If you want beer, go to a beer shop, if you want books go to a book
    shop! If you're in the middle of nowhere try borders.com.au (or
    amazon.com, etc.) If you're a bit new to this bike engines thing,
    the Haynes Motorcycle Basics Techbook looks pretty good. The other
    one to look at might be the Haynes XR250L book, because I suspect
    an XR250L and a XLX250 are pretty much the same thing (same engine,
    anyway, the suspension and carbie might be different but that's
    pretty general).
    The other option is to try and blag a microfisch reader from somewhere
    (they used to get thrown out a lot by libraries) and buy the workshop
    manual on fische for $15ish. You don't want to know what it costs
    on paper! (although no harm in checking out ebay or whatever) Even
    if you're getting the workshop manual, though, the Haynes basics book
    would be a good addition unless you're an expert already ...
    -----sharks
    sharkey, Mar 23, 2005
  8. Gary Smith
    sharkey Guest
    Actually, that's two I didn't mention. Make sure the clutch cable
    slides back and forth smoothly.
    Oh, and sometimes the 'coarse adjustment' is a funny looking
    widget part way along the clutch cable, a hex bit about an inch
    long with the cable screwed into each end.
    -----sharks
  9. Gary Smith
    Theo Bekkers Guest
    A cable adjuster? He needs a new cable, or learn to ride home without a
    clutch.
    Theo
    Theo Bekkers, Mar 23, 2005
  10. Gary Smith
    Theo Bekkers Guest
    That's why some manufacturers have different oil in the gearbox. Engine oil
    is not the best thing for gears.
    I'd be really worried if I had oil on my clutch.
    Theo
  11. Gary Smith
    sharkey Guest
    Yes, yes, me too on the Beemer, but the guy wasn't asking about tractors
    he was asking about a mid-eighties Honda. No point confusing the issue.
    -----sharks
  12. Gary Smith
    Gary Smith Guest
    Ok, i found the long adjuster on the clutch cable and readjusted it so i
    could screw in the one on the handlebars. I don't use the clutch when riding
    anyway. Never have. ridden 3 ct125's and a couple XL250's and XL500 without
    using clutch except for takeoff/stopping and never had a prob before. Rang
    Redwing honda and have a Clymers being sent COD next week. The guy there
    says the XLX is basically an XL bike with XR motor. the only difference was
    one motor was taller or longer than the other. Went for another fang today
    and it's still doing the no second gear for 10 seconds trick on me. Gonna
    get this book and pull the motor out and the tools and strip it. needs about
    another $300 bucks worth doing up top. Have put new oil in as well. can't
    remember the brand/details but it was looked up in the book at the petrol
    station. $25 - 4 litres.....Hmmmmm, funny how i remembered THAT bit!!
    This thing has started making a noise like a loose timing chain, however, it
    goes away after about 5-10 mins riding. WIERD. Has auto adjuster apparently
    but they should work instantaniously.
    Ok, that's it for now. Sharkey, still want some pics of this thing?? took
    some last night.
    Or go to bikepics.com. only have one there at the moment but will add more
    tomorrow.
    Thanks again.
    Gary
    Gary Smith, Mar 25, 2005
  13. Gary Smith
    sharkey Guest
    Well, there's a likely problem then! The clutch is dragging when you
    don't use it!
    Could be the balancer chain, could be the adjuster being sticky, could
    be just the tappets making you feel welcome.
    Nah, she's right, we've IDed the bugger now.
    -----sharks
    sharkey, Mar 25, 2005
  14. See Chris Deans post "HOW TO FIX A RATTLY SPADA" for a possibility on
    the timing chain rattle thing. I assume thats a similar vintage Honda
    motor, so the "automatic adjuster" may suffer similar issues.
    (Message-ID: <>)
    big
    Iain Chalmers, Mar 29, 2005
  15. Gary Smith
    Gary Smith Guest
    Yep, read that this morning thanks. Gonna strip the whole motor so i'll find
    out what it is then.
    Gary
    Gary Smith, Mar 29, 2005
