Hi Have a problem with a flat spot on my GN250 (1990) Runs fine on tickover - gets to 4000 revs and flat spots, no matter what gear in. Changed the plug first and gapping correct, cleaned the jets in the carb, airfilter is changed, timing ok. I am suspecting the carb diaphram but the screws are well stuck although have sprayed them with wd40 didnt want to force my way in. The bike has only done 19k miles so would expect that the needle in the carb should be ok, but pulling my hair out. Anyone had the same problem and fixed it. I have had the bike about 2 months and it has always had this problem. One thing if I rev past 4000 revs it picks up no problem
