GoldWing fettling update #27 (in a series of 325)
Discussion in 'UK Motorcycles' started by Salad Dodger, Nov 14, 2004.
  1. Salad Dodger
    Salad Dodger Guest
    I found that clip!
    It was in the bitzanbobz tray after all. Odd.
    Progress was halted by a need to fettle the Blackbird's clutch slave
    cylinder which had gone all to pot once more.[1]
    A quick strip, clean and fill/bleed took the thick end of an hour,
    then I had to go shopping for Madam.[2]
    Then fitted the pad retaining clip, secured the new brake lines to
    their clips, and refitted the battery box.
    This was a slightly more awkward job than expected[3], but success was
    achieved without breaking anything, or drawing blood.
    Then I had to refit the fluid reservoir, main fuse, battery, master
    cylinder, heat shields.
    So, a slow, but undisastrous day.
    It's all getting there, but slowly.
    .... and I've just won a new shiny electrical thing to bolt on, too.
    [1] I think I've twigged the cause. Jetwashing the area around the
    sprocket forces water and chain lube up through the drain hole under
    the slave cylinder, which then makes the slave piston all manky.
    [2] Baking supplies, for Children in need. Which is why I am freezing.
    If it gets warm, the cakes will go stale, or summat.
    [3] I'm a slow learner.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16931.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
  2. Salad Dodger
    Sounds good. I found my marbles again.
    Jetwashes are evil things that shouldn't be used on motorcycles.
    Muck, Nov 14, 2004
  3. Salad Dodger
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    I'm *so* glad you asked, it saved me the bother.
    Nigel Eaton, Nov 14, 2004
  4. Salad Dodger
    Nigel Eaton Guest
    Hmmm... Gotta get me one of them. But not until December the 1st.
    I have standards, y'know.
  5. Salad Dodger
    Salad Dodger Guest
    A brake switch box.
    Four switch chrome box wot fits on top of the brake reservoir.
    Ideal for all kinds of electrical switchery.
    The switches light up, too.
    All I've got to do now, is work ou what do connectthem too.
    1: Spotlamps
    2: Heated grips.
    3: Something else.
    4: Definitely not a set of red or blue neons to go behind the radiator
    grille. Oh no. As if.
    | ___ Salad Dodger
  6. Salad Dodger
    Nigel Eaton Guest
    Well. Yes. But nonetheless, they are recognisably standards.
    If you squint a bit.
    With your head on one side.
    From a distance.
  7. Salad Dodger
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Well, red or blue? Which is it?
    I know, go for *both*.
  8. Salad Dodger
    Cab Guest
    Depends if you're careful or not. I've never had any problems.
    Cab, Nov 14, 2004
  9. Salad Dodger
    Salad Dodger Guest
    I'd always thought I could resist the magpie effect. I mean, I put a
    chrome ignition lock surround on, just to shut up the members of the
    GWOCGB, and I thought I had it under control.
    Then I thought: a pair of discreet little pannier lights, what harm
    can it do?
    The same with the top box lights.
    and the fairing lights.
    and the cigar lighter switchbox
    and the vanity mirror,
    cubby dividers
    extra rear lights.
    I've currently got Rings of Fire, a new light rail for the rear (that
    was #3 for the switches - gonna wire 'em in as fogs) then the
    spotlamps, and now this switch box, and I don't feel like I'm in
    control any more.
    <sotto voce>
    Help. Me.
    Oh dear.
    | ___ Salad Dodger
  10. Salad Dodger
    Depends dunnit.
    Muck, Nov 14, 2004
  11. Salad Dodger
    Nigel Eaton Guest
    *Sniff* I can handle it, I've just got a bit of a cold, that's all.
    You'll be flogging your arse for LEDs and chrome before the year's out.
    You mark my words.
  12. Salad Dodger
    Nigel Eaton Guest
    It's Leeds.
    HTH.
  13. Salad Dodger
    "Now, Dodger was a good straight boy to begin with, but there was bad blood
    in him someway and he got into the chrome and the lights and that leads
    straight to glitter balls and metalflake, just like marywanna leads to
    heroin. You think you can take them LEDs or leave 'em, do you? Just buy a
    few for your bad days. Well, now we all have those bad days when you can't
    shine for shit. The more of that chrome you buy, the more bad days you have
    without it. So it comes down finally to all your days being bad without the
    bling. It's disco or nothing. Time to stop chippying around and kidding
    yourself. Kid, you're hooked. Heavy as lead."
    platypus, Nov 14, 2004
  14. Salad Dodger
    Salad Dodger Guest
    Well, it still *looks* standard (ish) at the moment.
    Aargh. Why did I put "at the moment" in there?
    I think I can still make it if I jump for the quayside.
    | ___ Salad Dodger
  15. Salad Dodger
    Salad Dodger Guest
    That should cut down on the purchases, then.
    | ___ Salad Dodger
  16. Salad Dodger
    Well spotted - it is William Burroughs, but it's from /The Black Rider/, Tom
    Waits album.
    platypus, Nov 15, 2004
  17. Salad Dodger
    Champ emerged from their own little world to say
    <breaking news>
    reports are coming in that a freak wave has caused havoc in Dover Harbour.
    Several small boats appear to be capsized
    </bn>
    wessie, Nov 15, 2004
  18. Salad Dodger
    Ben Guest
    Lower it by 4 inches, 18 inch alloys, flared wings and a Max Power
    sticker.
    Three out of four ain't bad.
    Ben, Nov 15, 2004
  19. Salad Dodger
    # My Heart Will Go On
    sweller, Nov 15, 2004
  20. <chortle> Oh dear :)
    Paul Corfield, Nov 15, 2004
