Good ride today...
Discussion in 'UK Motorcycles' started by Tosspot, Aug 31, 2008.
  1. Tosspot
    Tosspot Guest
  2. Tosspot
    des Guest
    des, Aug 31, 2008
  3. Tosspot
    Catman Guest
    My dad navigated them doing SAR from Coltishall back in the 70s. They
    have one of his at Hendon, which came as something of a shock when we
    took my young nephew up there a couple of years back. I would have been
    crawling around it at about the same age as he was.
    Oddly he seemed less impressed than I did.
    www.cuore-sportivo.co.uk
    Catman, Aug 31, 2008
  4. Tosspot
    Catman Guest
    Should have asked if they'd let me aboard the Westland :)
  5. Tosspot
    Beav Guest
    Did you like that massive shaft running up between you and the pilot?
    When that stops, it's time to clench.
    But full of "character". Sort of the FatBoy of the copter world. About as
    reliable too.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 31, 2008
  6. Tosspot
    Pip Luscher, Aug 31, 2008
  7. Tosspot
    Tosspot Guest
    Given it was a 27 litre, 9 cylinder engine between me and Dog, I was
    fucking impressed. A really odd take off, it rolls forward, comes up on
    the suspension, rolls a bit more and takesoff. You don't really know
    you're airborne. Think of a Stork takeoff, but blimey, you really know
    you're hanging under a big multicylinder engine.
  8. Tosspot
    Catman Guest
    I never flew in the Whirlwind, but AIUI they (the Wessexes) were turbine
    powered. Which made things a bit less 'visceral'.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Tosspot
    ITYM "sitting just behind".
    Wicked Uncle Nigel, Aug 31, 2008
  10. Was it not the case that the modernisation of the aircraft with a
    turbine saved it from the bin? Istr something along those lines years
    ago, relating to Westland. I also str something about the originals with
    piston engines were horribly unreliable, which probably relates to the
    first point.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Sep 1, 2008
  11. Tosspot
    Beav Guest
    A big **** off radial engine in the nose, with the drive shaft running
    between the two front seats. Later "turbined" versions you can easily tell
    by the exhausts sprouting out of each side of the nose. Still needed the
    shaft between the seats though in order to drive the gearbox asbove the
    heads of the occupants.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 1, 2008
  12. Tosspot
    Beav Guest
    Indeed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 1, 2008
  13. Tosspot
    Tosspot Guest
    Yeah, I did start thinking I don't mind if it crashes before my flight,
    or after it, but not during. Very Harleyesque, vibrates like a busted
    dildo.
    Tosspot, Sep 1, 2008
  14. Tosspot
    Catman Guest
    Was googling idly yesterday, and it does appear to be the case. I
    certainly am no expert, though.
    Catman, Sep 1, 2008
  15. Tosspot
    Catman Guest
    Very distinctive.
    ISTR that bit. I was only young.
    Catman, Sep 1, 2008
  16. Tosspot
    One of my exes had a busted vibrator, every time she used it I thought
    she was going to knock her teeth out.
    Lozzo, Sep 1, 2008
