Got it started, but...
Discussion in 'UK Motorcycles' started by Paul Carmichael, Feb 7, 2010.
  1. Started bike with jump leads from car battery. Started after about 4
    turns. But when I disconnect the jump leads, it almost stops. Chugs like
    an old knacker. Reconnect the leads and runs smooth.
    Ok. I presume the battery is having trouble making sparks, but does this
    mean the alternator is buggered? I suppose I ought to stick a meter on it.
  2. Paul Carmichael
    Steve Guest
    I think fuel injected bikes need a healthy voltage to run but ICBW.
    Don't bugger about - stick an Odyssey battery in it.
    Steve
    Steve, Feb 7, 2010
  3. It's carbed.
  4. It gets worse. Now it won't run at all without the car battery attached.
    Even after it was warmed up.
    Bollocks.
  5. Paul Carmichael
    Pete Fisher Guest
    Utterly shagged battery, or bad connections - with earth being the most
    likely culprit. I've had the same twice now on the 'tart', with the
    added fun of random total electrics loss before final diagnosis. Starts
    on jump leads - dies when disconnected. That tends to 'boil' the battery
    because of it's position though.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 7, 2010
  6. Paul Carmichael
    Pete Fisher Guest
    Definitely FUBAR battery then IME.
  7. Paul Carmichael
    If Paul is connecting both jump leads directly to the battery then there
    won't be an earth problem on the bike. Conversely, if Paul is connecting
    the negative from the car to the engine block/frame then a poor earth
    from the bike battery is certain.
    If not the earth then most likely, the underused battery has developed a
    short circuit cell. This is enough to sink all of the output current
    from the alternator. Next would be the regulator, then alternator.
    Someone with a meter & a clue should be able to establish which in
    fairly short order.
    wessie, Feb 7, 2010
  8. Paul Carmichael
    Pete Fisher Guest
    If connecting jump leads direct to the battery by clamping on to the
    existing battery connection you can still get issues particularly on the
    earth side. More a problem with car type round post batteries with cap
    type connections TBF, as on a bike you can usually see the green fur
    that suggests a bad connection or get on to the battery post itself.
    I've experienced it a couple of times on SOCs. The cure is obviously to
    remove the connections and clean them up.
    My money is on the battery. When I had it on the Voxan the experts here
    were most dismissive, but Patrick at Pointe de Corde guessed what it was
    as soon as I told him the symptoms.
  9. Battery to battery.
    I left it on the Optimate when I went down the pub (yes, I was that
    angry) and now it is reported as healthy. I'll have another play
    tomorrow. If it starts and runs, I'll put the Avometer on it. If one cell
    on the battery is duff, wouldn't the Optimate say it was knackered?
  10. Update: Just been out to the shed and put the Avometer across the battery
    (Optimate says wonderful) - 14V. Fine. Put it back on the Optimate and
    the red light comes on. I think my Optimate's shagged.
  11. Paul Carmichael
    Wouldn't be the first one to go that way - I'm on my second and my
    daughter has just bought her third one after the previous ones packed
    up.
    Lozzo, Feb 7, 2010
  12. Paul Carmichael
    if a cell is sulphated sometimes the Optimate can recover it as it uses an
    algorithm rather than a simple trickle charge. Up to 22V is used to apply
    the electrical equivalent of "hit it with an 'ammer".
    http://www.accumate.co.uk/optimate 4 flow chart.pdf
    Where an Optimate lets you down is by giving a false positive i.e. the
    green "your battery is okay" LED comes on. This just means that the battery
    held enough volts to pass the test. The Optimate does not do a load test
    and can't tell for sure if the battery has enough Amps available to start
    your bike. The Optimate can be fooled when a battery has a high internal
    resistance.
    For a fully discharged battery I would not expect the battery to be
    recovered by an Optimate after a few hours down the pub. It usually takes
    an overnight session. So, if you have a fully charged indication on the
    Optimate already I suspect you have a battery that has Volts and a higher
    than optimum internal resistance which will deliver fewer Amps than
    desired.
    wessie, Feb 7, 2010
  13. Paul Carmichael
    Did you disconnect the Optimate from the power source? My Optimate is a Mk1
    and it does not like to be re-connected to a battery unless the mains plug
    has been removed from the wall socket.
    wessie, Feb 7, 2010
  14. I always pull the mains plug and then disconnect the battery. It's
    instinct since a certain incident involving a battery on charge, a
    starter motor that needed testing and a trip to the hospital at high
    speed.
  15. Paul Carmichael
    crn Guest
    ISTR the Optimate charges at around 1 amp. A typical bike battery is
    around 10AH so if it claims to be fully charged in less than 10 hours
    from fully flat this suggests that the battery is fucked.
    Adjust the artithmetic as required.
    You might get a few more weeks out of it after a day or so on trickle
    charge but time to order a decent new battery.
    Yuasa or Varta. YKIMS.
    crn, Feb 7, 2010
  16. Paul Carmichael
    Post corrected.
    Lozzo, Feb 7, 2010
  17. Paul Carmichael
    My Quota - with Italian electrics - will happily run when the voltage
    droops to the point where the indicators are noticeably dim in
    daylight and the electronic tacho needle is sagging to indicate a
    thousabd RPM too low. I don't know exactly what voltage that was but
    the tacho perked up again when I turned the lights off.
    This I learned when the alternator fried a year or so ago.
    If you think about it, they have to work even when the motor is
    cranking on the starter.
    Pip Luscher, Feb 7, 2010
  18. Paul Carmichael
    zymurgy Guest
    Don't **** about, buy a new battery. Better that, than getting
    stranded somewhere with a bike that won't start ...
    Paul.
    zymurgy, Feb 8, 2010
  19. Er, what about "TAB MOTO"? 50€ from the local bike shop. We shall see -
    not today though, as it's pissing down.
    Paul Carmichael, Feb 10, 2010
  20. Paul Carmichael
    crn Guest
    Depends on how long you plan to keep the bike. Cheap shit batteries are
    a false economy but if you just want it to work for long enough to
    Nige it out you could save a few quid.
    crn, Feb 10, 2010
