Gowenlochs....
Discussion in 'Australian Motorcycles' started by James, Feb 10, 2004.
  1. James
    James Guest
    Hi All,
    Was having trouble starting the Duck (748) - It sounded like the
    battery was flattening. Was turning over slower every time and
    eventually I had to clutch start it. Took it to gowenlochs and they
    said it was a Regulater? That was $10 and $60 labour as it took him a
    while to deceide this was the case. Had to get the bike jump started
    to get home. Next day - same shit wouldn't start so I took it back
    and they said I needed a new battery - $145 - no probs...
    Next day I had to clutch start it again and took it back and they told
    me it was my starter motor and they could do me a second hand one for
    $600...
    Does anyone know a decent ducati shop? What about northside?
    Cheers
    James
    James, Feb 10, 2004
  2. Ahhh! I've figured out your problem.
    You've got a broken Ducati Shop, and you'll need a new one.
    I can do you a reconditioned one for..............
    James Mayfield, Feb 11, 2004
  3. Obvs. not the problem,would not have been the regulator for only $10 thats
    more like a fuse price , unless he cocked it up and it was $60 for the reg.
    (still to cheap) and $10 labour ?
    Have you been starting it with jumper-leads this can fry the electrics if
    done wrong?
    Bypass all these so called experts and head for a proper auto.elec. who
    knows what they are doing
    They would run some tests and have it sorted in no time at a fair price
    The weak link in most motor field is the dealers workshops and mechanics
    "NFI"
    Yellow pages is your friend
    No need for a newie ,these can be rewired
    Frasers or Bologna Italy
    CDIHL
    TerracottaWarrior®, Feb 11, 2004
  4. James
    FuTAnT Guest
    It can be a combination of problems, but I'm sure they've fixed em all now!
    Sometime the starter motor will get a dead section in the windings or they
    burn out etc and can 'cause slow or no starting if they are currently at the
    "dead" point when trying to start. If you've got a new battery and it's
    fully charged and it still won't turn over properly then yeh, sounds like
    the starter is fucked. Take it to an motor rewinder or something and get
    them to reco it for you, should be able to do it no probs.
    Often these things can happen in threes, I know my electrics on the
    (notorisouly bad electrically) GSX250S were like this. I replaced numerous
    batteries and finally replaced the reg with a high current aftermarket one.
    I still reckon the stator was probably semi fucked but never bothered to
    replace it. (or did I, actually, I think I did, 2nd hand why not eh?) but
    the starter was atleast always ok.
    Still sounds like the mechanic didn't quite know what he was on about. Takes
    a little while to test for the problems but not long (20 mins tops) then it
    should be pretty obvious what exactly is going wrong.
    Cam
    '03 954
    FuTAnT, Feb 11, 2004
  5. James
    smack Guest
    Reds in Penrith... but maybe you need a sparkie, not a mechanic
    smack, Feb 11, 2004
  6. Yes,the GSX250 was notorisoul for doing that...
    Psotmna Pta
    Pat Heslewood, Feb 11, 2004
  7. James
    Johnnie5 Guest
    i read most of what you have to say Hatz but now you are relly pulling it
    you do know why its NFI ???
    Johnnie5, Feb 11, 2004
  8. James
    Johnnie5 Guest
    $10 would have got you nothing
    a regulator is $400+
    did you up them for the $70 that didnt fix it the first time ??
    what about the $145 for a new battery that still hasnt fixed it ??
    gowies are usually very good but guess you got the poor service that always
    comes around
    sometimes
    electrickery is sometimes a black art
    starter motors are a common problem
    also check the connections to the starter motor they are easy to get to if
    you remove the right hand fairing
    water gets into it and rusts it and gives a poor connection and makes it
    hard to start
    reds penrith
    ducks need a good charge , near max charge to have them start
    it will also take a long ride to charge them as they use so much power
    between headlight ,
    fuel pump and electrics
  9. James
    Johnnie5 Guest
    what happens if you jump start the bike ? does the starter turn easy ??
    check those connections, try again and if no joy prob be
    looking at a starter motor
  10. On 11/2/04 9:25 AM, in article
    So, you don¹t want one of their stickers?
    Hammo
    Hamish Alker-Jones, Feb 11, 2004
  11. 10/10 you learn quick....
    Hammo
  12. Ha ha... Ha hah hah hah hah *cough* *choke* *spit*!
    No, _not_ Northside...
    big
    Iain Chalmers, Feb 11, 2004
  13. James
    sharkey Guest
    I thought the GXS520 was the notorisoul eon.
    -----shraks
    sharkey, Feb 12, 2004
  14. If Frasers (NFI) have "nfi" then that is sad
    Those guys are the offical import agent and have direct contact with the
    factory and can get all the tech. support and help for any sort of problem.
    In any case in a few years Ducati SpA will take over as the offical
    importers and set up a factory owned business here in Oz just as soon as the
    volume has reached the magic target level,prices *w/sh/ould* fall too
    They have been doing this in more and more markets worldwide.Jappers have
    been doing it like that for decades it is the only way if you are going to
    be serious
    CDIHL
    TerracottaWarrior®, Feb 12, 2004
  15. James
    Johnnie5 Guest
    sad but true, they make money and couldnt really give a shit IMHO
    have you seen the service myth ad in magazines with i am assuming fraser
    himself
    in overalls and holding a spanner LMAO
    it says a 'minor' service and a more 'inclusive' service
    wondering who the marketing chief was for that piece of information
    problem.
    yeh but they cant get me some stickers for more than 8 weeks so i ring north
    coast and he has
    several on the shelf in my hands in 2 days along with all the seals i
    needed for the clutch slave
    douut it
    prices wont change as they are making money , ducati is becoming more and
    more
    harley esqe every day that goes by , a marketing company
    Johnnie5, Feb 12, 2004
  16. James
    Biggus Guest
    OH WHAT A FEELING.....................
    Biggus, Feb 12, 2004
  17. James
    Biggus Guest
    Now we know your a moron Hatz
  18. Johnnie5 wrote:
    The couple of times I've asked them for parts other than oil, O-rings or
    gaskets it's been the same story. None in the country, they'll have to
    order 'em in, could take four weeks. Say, "**** that," get the part number
    and ring Morgan and Wackers. "No worries mate, got half a dozen out the
    back." Sweet, 25% cheaper to boot!
    Donut about you but I doubt it. At least the importer will be accountable
    for the product they sell. Harley's supposed to be giving Frasers the
    flick too. Frasers have made squillions (in land alone). They can't be in it for the money
    and couldn't give a **** about motorcycles or their customers so they must
    just be doing it to piss off the respective motor companies!
    Pisshead Pete, Feb 12, 2004
  19. Sounds like he needs a Spada.
    Postman Pat (Got offered a VTR250 and VTR1000 yesterday)
    Pat Heslewood, Feb 12, 2004
Similar Threads
Loading...
