gps mount on handlebars
Discussion in 'UK Motorcycles' started by gazz, Apr 29, 2008.
  1. gazz
    gazz Guest
    want to put my garmin nuvi 250W on the new bike, so it sits just above the
    yokes, it's too wide to fit between them.
    whats the recomendations for doing this, i want the gps to sit as close to
    the bars as possible, i.e. i dont want it on the end of one of those ball
    mounts with the stalks between them if i can help it, but the thing needs to
    mount onto the bars between the yokes, so need it to raise it about an inch
    if that,
    dont think i'll need to tilt and swivel it, on the scoot i just got a
    universal pda mount and screwed it flat onto the 'dash' next to the rev
    counter, was pointin slightly to the right, but i could see it easily
    enough.
    i know the nuvi 250 isnt waterproof (ram are bringing out an aquabox big
    enough for the wide models mid may, but that'll muffle the speaker totaly,
    and make it hard to connect the charging lead i imagine)
    and i also know it hasnt got an audio out to feed an intercom, but when the
    warrenty is up i may open the fucker up and see if i can piggy back a 3.5mm
    mono earphone connector off the internal speaker, but not expecting there to
    be room inside for that to happen really.
    gazz, Apr 29, 2008
  2. gazz
    [snip]
    I bought a mount for my TomTom One Europe - it's basically a two part
    kit consisting of:
    * a clamp that fits round the bars (with a number of thing rubber
    inserts that you use to match the diameter of the bars). This can be
    angled and then tightened. It's flat on one side, with lugs that
    connect to...
    * a specific mount for the GPS - this slides onto the clamp and
    "clicks" into place. The GPS then slides onto this as it does the
    suction mount that came with it.
    Note, it doesn't tiltor swivle when it's fitted and tightened, so
    there's a bit of messing around to get it in a position you like.
    I got it from ebay, for around £14 delivered, from these people:
    http://myworld.ebay.co.uk/selectnav
    They might do one for your nuvi.
    darsy, Apr 29, 2008
  3. gazz
    Ben Guest
    Sounds interesting as I have a TT One. What are you doing for
    waterproofing?
    Ben, Apr 29, 2008
  4. gazz
    so far, nothing. I'm only really half-heartedly experimenting with the
    SatNav on the bike (currently the powerlead runs from under the seat
    across the tank and is just cable-tied to the bars - I couldn't be
    arsed trying to take the tank off[1] and routing it underneath). I
    really don't ride in the rain unless I have to - for the French run,
    if it's a bit wet, I might cover the TomTom with a clear sandwich bag
    and tie; if it's pissing down, I just won't use it.
    A couple of years ago, someone posted a link to someone selling latex
    sheaths designed for this application (as opposed to just using an
    actual condom, which I've also seen done), but I'm buggered if I can
    find the link.
    [1] paging Krusty: is this as difficult as it looks on a Tiger?
    darsy, Apr 29, 2008
  5. gazz
    Ben Guest
    I need to get myself a cigarette lighter socket to connect to the
    battery and stick under the seat. I was then just going to shove the
    unit into the map pocket of my tankbag.
    Given I'm going to Scotland in September on the thing, waterproof is a
    bit of a requirement
    Ben, Apr 29, 2008
  6. gazz
    yeah, that'd work.
    I sold my magnetic tank bag to someone about 7 years ago, and I doubt
    one would fit on the Tiger's tank anyway (far too round).
    oh, god yes. It'll piss down at least once ever day you're there.
    darsy, Apr 29, 2008
  7. gazz
    Ben Guest
    Best of all, I'm going in order to attend a wedding.
    On a boat.
    On a loch.
    In the Highlands.
    Can you get Goretex black tie?
    Ben, Apr 29, 2008
  8. gazz
    yes.
    darsy, Apr 29, 2008
  9. gazz
    and may blow off in the wind. IIRC the tank is either plastic or Al
    wessie, Apr 29, 2008
  10. gazz
    gazz Guest
    excelent, i shall order one in a few sex,
    now for a reasonably priced garmin 12 volt power cable, fucked if im paying
    over 20 quid for a 12 volt to 5 volt fag lighter plug and a mini usb plug on
    the end of a bit of cable,
    gazz, Apr 29, 2008
  11. gazz
    I've only done it once, but it wasn't too bad iirc, other than the
    petrol pissing out when you disconnect the pipes as they don't
    self-seal (at least they didn't on mine). Just be very careful with the
    pipes as the fittings break easily, especially if they haven't been
    replaced under the recall.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, May 2, 2008
