GPZ 500z indicator relay?
Discussion in 'UK Motorcycles' started by Harry Bloomfield, Jul 17, 2004.
  1. Hi all,
    I am flumoxed.....
    Two GPZ 500s ('88 and '90), now both with the same problem after my lad
    swapped indicator units from his to mine, in attempting to fix his none
    working indicators.
    The wiring of both seems to be same/similar.
    At the flasher relay socket a +12v via a brown wire, ground via a
    black/yellow and orange which goes to the switch. The actual indicator
    relay (on both) is however a two pin job, which is only connected to
    ground and the orange wire which goes to the handlebar switch. The
    brown positive seems to have no connection. From the switch it goes to
    the lights of each side + warning lights, then to ground from each
    light.
    If I link across the relay socket between brown and orange, the lights
    come on and stay on as you would expect, depending upon the switch
    position.
    Having swapped the relays from one bike to the other, now the
    indicators on neither bike work. What has me flumoxed, is how they
    could have ever worked with no apparent connection to the brown to
    provide a positive (+12v) supply.
    My best guess is that there was some sort of adaptor between the socket
    and the relay which he has managed to loose on both bikes.
    Could someone take a look at their relay and see if the socket is a
    three terminal and the relay a two terminal job please?
  2. Harry Bloomfield formulated the question :
    A diagram might be worth while:-
    3pin relay socket .---.
    |-| L |-|
    | .---. | Left
    brown (+12v) orange o-----|-| L |-|
    ------------o o----------o---- .---. |
    o o-----|-| L |-|
    | | .---. | Right
    | blk/yell |-| L |-|
    | (ground) '---' |
    |To ground
    The relay only has two pins, which connect to orange plus ground.
