GPZ problem - Help required
Discussion in 'UK Motorcycles' started by GPZ, Apr 14, 2005.
  1. GPZ
    GPZ Guest
    Started the bike up this morning and started the daily ride to work. Ten
    miles in and the acceleration begins to get a little jumpy. Thinking I could
    be running out of petrol I switched to reserve. Came to the bottom of the
    A465 and gave it some beans and after 500 yards lose everything. Engine
    cuts, lights go out. Pull to the side and all electrics lost. Managed to get
    the bike to work and stick the battery on charge. End of day, put battery
    back in (Reading 12V) turn ignition key, neutral and oil light come on,
    battery reading drops to 7V. Can't even get enough power out of the battery
    to turn the engine.
    Apart from selling it and getting a GXSR, any other suggestions as to what
    the problem is.
    Thanks.
    GPZ, Apr 14, 2005
  2. GPZ wrote
    With only 7 volts it is either:
    2 cells gone together, unlikely but I have heard of it more than once.
    A mechanically bad connection halfway along inside the battery. Don't
    fancy it.
    Something external to the battery drawing shedloads of juice and
    obviously not fused. Probably you would smell burning as well.
    Battery prolly.
    As solutions to all of the above possible causes will involve a certain
    amount of dismantling around the battery you may as well get it out and
    test it on load on the bench as your first move.
    steve auvache, Apr 14, 2005
  3. GPZ
    GPZ Guest
    Tested on the bench and it reas 12V. It's only when I turn the ignition on
    it drops to 7V
    GPZ, Apr 14, 2005
  4. GPZ wrote
    Turning on the ignition puts a (I haven't got a clue) 3-4amp load on it?
    Got a handy car headlamp or two?
  5. GPZ
    tallbloke Guest
    May still read 12v unloaded, but be low on charge. If you jump start the
    bike and measure voltage with the engine running you should get arount
    13.8V. If it's not lifting the battery voltage with the engine running
    your bike isn't charging.
    tallbloke, Apr 14, 2005
  6. GPZ
    GPZ Guest
    Would that point to an alternator problem as well or am I being a TC.
    GPZ, Apr 14, 2005
  7. In uk.rec.motorcycles, GPZ amazed us all with this pearl of wisdom:
    Battery. Get a new one.
    Whinging Courier, Apr 14, 2005
  8. GPZ
    tallbloke Guest
    Well if it's not charging then either the battery is buggered or there is
    a fault in the charging system. Try putting a known good battery in
    circuit and checking to see if it charges. If not, check all the
    connections in the charging circuit before you start crying about the cost
    of spare alternator stators.
    Hope it turns out to b e the cheapest to fix possibility.
  9. Measure both coils. Looks like one of them has some shorted turns.
    Either that, or the IC igniter has possibly croaked.
    I would start by disconnecting these things, one by one, but not with
    the ignition live and see which one it is pulling the +12V down.
    Siwtch on, measure, switch off, disconnect one thing, back to start of
    this sequence.
    Also be sure all running lights are off. Any alarmy type bollocks
    fitted?
    Later.
    Steve Uzochukwu, Apr 14, 2005
  10. GPZ
    GPZ Guest
    Fitted new battery today and all seemed well. Pull up to 5000 rpm and the
    power delivery becomes jerky. Managed to get home and booked it into the
    local garage.
    Have come to the conclusion it is a piece of shit and I really need to get a
    new bike.
    Lost all confidence in the unfaithful bitch.
    GPZ, Apr 15, 2005
  11. GPZ
    GPZ emerged from their own little world to say
    Have you checked the earth straps? Especially where they join the
    engine/frame. Probably corroded or loose and as you increase the revs the
    buzziness makes the poor connection worse.
    get a new bike.
    It was a piece of shit when it left the factory :)
    wessie, Apr 15, 2005
  12. GPZ
    GPZ Guest
    Good point.
    GPZ, Apr 15, 2005
