GPz750 Pt 2... the colour of sparks..
Discussion in 'UK Motorcycles' started by Don, Nov 13, 2005.
  1. Don
    Don Guest
    ok, so the GPz that step son has inherited that wouldnt run properly (titled
    no grunt...)...
    Carbs stripped cleaned. Not really much in the way of potential trouble can
    be seen... jets are clear, floats are mobile and not split, and basicly all
    looks ok. Given a good hosing down with carb cleaner and blasted through
    from the compressor and all seems hunky dorey. Air mixture screws checked
    and re-set.
    Now the bugger refuses to start. Battery is fully charged, and plugs new
    and correctly gapped. When I remove the plugs and earth them against the
    engine casing and turn the engine over, the spark is of a fairly week yellow
    nature. Now, IIRC (and I may be wrong) the spark should be big, fat and
    blue/white.. Is this correct?... If so, are we looking at a potentially
    knackered coil?...
    Pointers please people...Coz its getting cold, and my back is protesting at
    being bent over this machine all the time!
    Don, Nov 13, 2005
  2. Green, actually. Centre should be purple.
    The Older Gentleman, Nov 13, 2005
  3. Don
    Which is precisely the opposite to my experience. I've found they will
    quite happily work at lower revs but they break down under load.
    ...but if the coil feed (earthing IIRC) wires are reversed the timing will
    be wrong and it won't start.
    sweller, Nov 13, 2005
  4. Don
    Don Guest
    Yep. Diaphragms all fine and dandy.
    Well, it started after mucho hassle and a couple of battery draining
    sessions
    OK, so this may be a tree Im barking up incorrectly
    OK, didnt realise that. Ill double check on all cylinders.
    OK, if were still looking at the carbs, what bits to double check? Jets are
    clear. Air feed tube to pilot jet seems clear (ie air gets blasted through
    it from compressor and I can feel it coming through into main carb body).
    Diphragms are intact. Needles are moving freely. Float needle valves all
    free and working fine. Float bowls are filling up (checked via drain
    screws)... where else should I be checking?...
    Don, Nov 13, 2005
  5. Don
    My money is on ignition. How old are the plugs?
  6. Check all low tension wires and pay special attention to the
    connections. A slight resistance due to corrosion/dirt makes a helluva
    difference to the state of the spark. Especially check the wires to the
    trigger on the end of the crankshaft.
    Grimly Curmudgeon, Nov 13, 2005
  7. <AOL>
    And *then* they refuse to work at all.
