Grease
Discussion in 'UK Motorcycles' started by ogden, Aug 18, 2009.
  1. ogden
    Stainless steel screw into aluminium internal thread.
    Copper grease?
    Lithium grease?
    Bacon fat?
    Beef tallow?
    Dry?
    ogden, Aug 18, 2009
  2. ogden
    zymurgy Guest
    or with a dab of threadlock.
    It depends ...
    Paul.
    zymurgy, Aug 18, 2009
  3. ogden
    Hog, Aug 18, 2009
  4. Grimly Curmudgeon, Aug 18, 2009
  5. I've got a big tin of copper grease. I've had it about 25 years, and
    it's maybe one-third used. I think it will see me out.
    The Older Gentleman, Aug 18, 2009
  6. ogden
    zymurgy Guest
    That's a new variation on 'the sands of time' !
    I've a little pot of Copaslip, about 1/2 used, I hope it doesn't see
    me out ... :)
    Paul.
    zymurgy, Aug 19, 2009
  7. ogden
    TOG@Toil Guest
    Heh, yes, I suppose so. I just bought a large tub of the stuff in the
    mid-1980s (when I was stewarding various Moto Guzzis; need I say
    more?) on the basis that: "Oh, this should last a while, and those
    damn tubes always get punctured...".
    It's one of those things I am never, ever going to run out of. The
    sort of garage equivalent of that bottle of oddly coloured Spanish
    liqueur that everyone has at the back of the drinks cupboard. Another
    is Loyblox (those rubberised polishing blocks): I got given a set, in
    different grades, at about the same time and they never seem to wear
    out.
    WD40, on the other hand: I never seem to have any in the garage when I
    need it, despite buying the stuff all the damn time. And as sure as
    eggs is eggs, every time I reach for the tube of gasket goo - any tube
    of gasket goo - it's always solidified.
    TOG@Toil, Aug 19, 2009
  8. ogden
    I buy it a gallon at a time. Costs less than 15 quid, comes with a
    trigger spray bottle into which one decants the liquid, lasts for ages.
    One gallon lasted me /and/ Loz over four years, for example.
    Decided against WD40 last time, have Duck Oil this time - seems to be
    more effective as a lubricant and most importantly, it smells better.
    It may not be as effective as a penetrating oil, but I have a can of
    Prolong SPL 100:
    http://www.hansonoil.com/prolong-spl100-super-penetrating-lubricant-
    12oz-236ml-p-44.html
    - which , while it may sound like a cure for premature ejaculation (and
    it may be, I've never had cause to try it) is far superior to WD40 in
    the penetrating stakes and it has the bonus side-effect of decomposing
    Loctite if left for ten minutes on a stubborn bolt thread. And it
    smells nice too.
    The only downside of the Prolong spray is that it is rather expensive
    (expensive enough, perhaps, to do what it claims on the tin) but that
    means it is only brought into use when needed and only ever used with
    the tube, never sprayed gaily around from an open nozzle. I use it in
    preference to Copaslip in many places too, such as car wheel bolt
    threads as it is less messy and doesn't attract every iota of grot for
    miles around, as the coppery stuff tends to.
    Pip, Aug 19, 2009
  9. ogden
    Beav Guest
    Anti seize compound.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 21, 2009
