GSX in 'runs spot on' shocker
Discussion in 'UK Motorcycles' started by JackH, Feb 9, 2010.
  1. JackH
    JackH Guest
    Amazing how much difference having properly set up carbs makes, isn't
    it.
    Picked the behemoth up this afternoon - started first time and pulled
    its revs up straightaway, something it hasn't been keen to do the
    whole time I've had it.
    Possibly something to do with the pipe broken off the side of carb two
    actually turning out to be the feed to the choke mechanism - without
    this, it was getting more air than normal rather than fuel when the
    choke was on.
    And now the really unexpected bit...
    When I bought this, I accepted that, what with it being a big heavy
    nekkid bruiser, it was never going to be all that on fuel.
    The best I'd got out of it up until now was 34mpg.
    Today, as well as pulling through with much more vigour through the
    mid-range, it's done 40mpg over a mix of country lanes and A roads,
    and without me being particularly shy of the throttle.
    I don't think that's bad at all for something this hefty. :)
    JackH, Feb 9, 2010
  2. JackH
    Catman Guest
    JackH wrote:
    I'd think that's bloody good. ISTR my Sprint only does about 34ish. ICBA
    to check though.
    www.cuore-sportivo.co.uk
    Catman, Feb 9, 2010
  3. JackH
    JackH Guest
    In the defence of all the faired stuff I've had, whereas I could
    generally blat along at 'eek' mph on those for mile after mile,
    anything about 80 on this for any length of time knackers your arms
    out, so I tend to not be hammering along quite as quickly.
    But... I've been dropping it down and giving it full beans to clear
    cars etc, plus the occasional blast, so yes, bloody good... especially
    given I used to only get about 43mpg out of VFR750/800s on a run.
    Be interesting to see how long it'll be before the carbs go off again.
    <cue predictable 'it'll be long after you've sold it' style comments>
    JackH, Feb 9, 2010
  4. JackH
    Catman Guest
    I suppose that may have a bearing. Most of my miles were clearish
    motorway, so 80 was typical speed.
    Not from me.
    Catman, Feb 9, 2010
  5. JackH
    rick Guest
    That sounds piss poor to me. My Sprint usually gets 50+ per gallon
    (including some *very* high speed blasts). The only time it's ever dropped
    below 50 is in the rush hour in London when it does around 45.
    rick, Feb 9, 2010
  6. JackH
    JackH Guest
    Last tank before this went into be fettled, I'd ridden it in a similar
    stylee to today, and got 28mpg.
    Given it's a sort of B12 in drag and the low figures some have
    reported for those around these parts, I'd assumed it was just the way
    it was, and decided maybe I'd not be riding it about as much I'd have
    liked.
    JackH, Feb 9, 2010
  7. JackH
    Catman Guest
    Sure it never got that good. I may mis-recall. Simon Wilson may recall,
    as we had some chats about his Bandit.
    Catman, Feb 9, 2010
  8. JackH
    frag Guest
    JackH took a blunt brush and painted...
    Nige, is that you?
    frag, Feb 12, 2010
  9. JackH
    JackH Guest
    No... it isn't.
    Was the point of the comment above lost on you?
    JackH, Feb 12, 2010
