GSX-R Handlebar Conversion
Discussion in 'UK Motorcycles' started by Gixxerman, Feb 15, 2008.
  1. Gixxerman
    Gixxerman Guest
    hi all
    i'm going to convert my gsx-r 600 k4 from clip-ons to a raise
    Handlebar, i've been watching for some conversion kit's and they are
    expensive, since i only need the top yoke.
    two question's
    Were can i buy a top yoke, ( lsl only sell the kit with all the stuff
    needed ) ...
    or since i have the possibility to make one top yoke, where can i find
    the measures of the oem top yoke, CAD drawing or pdf file or other.
    Thanks
    Jaime
  2. Gixxerman
    Eiron Guest
    ebay.
    Go to your local Suzuki dealer with a tape measure and see if
    a Bandit yoke will fit. Then change your pseudonym to Apehangerman.
    Eiron, Feb 15, 2008
  3. Gixxerman
    Or a breaker. Must be loads of straight top yokes attached to bent
    forks, hanging around.
    Hog is your man for this - he put flat bars on his Gixxer Thou - in
    fact, he puts raisers and flat bars on everything.
    Pip, Feb 15, 2008
  4. Gixxerman
    antonye Guest
    Don't bother with that, find out the width of the forks (I think
    they're
    50mm iirc) and then find something that has clip-ons with built in
    risers
    that are also the same size, eg Ducati SS are 50mm and look like this:
    http://amsmotors.com/95duc/drbar.jpg
    That's give you a nice easy and cheap way to raise the bars if that's
    all you need to do.
    antonye, Feb 15, 2008
  5. Gixxerman
    <perk>
    Ho Yuss.
    www.streetfighterstore.co.uk/gsxr_600/121
    ABM conversion was what I used on a GSXR1000. Use a set of raask adjustable
    jota bars.
    Hog, Feb 15, 2008
  6. Gixxerman
    Gixxerman Guest
    thanks for the posts
    they gave me new ideas, to work on...
    Regards
    Jaime
    Portugal
  7. Gixxerman
    Beav Guest
    A man with sense then.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 15, 2008
