GSXR 1000 "FI" Warning and Dealer Mode - Anyone ??
Discussion in 'Australian Motorcycles' started by Mick, Jul 14, 2007.
  1. Mick
    Mick Guest
    Hi all
    I have a 2003 GSXR 1000. Sometimes the warning light comes on when I'm
    riding and the temperature display keeps flashing "FI" . I understand this
    means one of the sensors on the bike is failing a test. Apparantly this is
    fairly common for these bikes judging by a quick google I did. I've read
    that it's possible to get the dash to go into "dealer mode" by shorting a
    couple of pins on a particuler connector together so that the display shows
    the error code for the faulty sensor. I've found the connector described in
    other posts (a white connector block with a black rubber boot covering the
    pins, located under the rear seat cowl).
    Unfortunately the instructions I've found so far say there are only two
    wires on this connector but I have 4. Their colours are : Orange/White,
    Red/White, Black/white and grey. Can anyone tell me which two wires I need
    to short together to get the bike to go into dealer mode ??
    I already have the error codes so no need to dig them up...
    Any info you guys can provide would be greatly appreciated cause this is
    starting to annoy me!
    Mick, Jul 14, 2007
  2. Mick
    fred.kroft Guest
    I only have a 2001/2002 man-well (I'm an ex-gixxer owner).
    What you could do is get a 10k resistor, and connect each
    wire combination. A 10k resistor will still pull down most
    lines (logic family), yet will limit current.
    fred.kroft, Jul 14, 2007
  3. Mick
    Blondie Guest
    Why don't you just take it back to the dealer and have them fix it ?
    Blondie, Jul 15, 2007
  4. Mick
    justAL Guest
    You should be able to find the how to on this at gixxer.com. If you've got
    a Powercommander I'd check the connections around the injectors by
    unplugging and plugging them back in. Sometimes a loose connector or
    moisture can give you an intermittant read out.
    justAL
    justAL, Jul 15, 2007
  5. Mick
    rockit Guest
    This info relates to a K1, so might not be applicable
    Anyway, mine has 2 plugs in that location; one 4 pin with only 2 wires
    wht\red, blk\wht, which is the dealer mode plug - just use the 2 connected
    terminals -same colour code might apply to yours?
    The other plug has ~ 6 wires, and is the reprogramming plug - I think?
    Mine occasionally shows the F1 light, and I have previously posted about
    it - relates to the butterfly in the intermediate exhaust pipe. If you get
    into dealer mode and find your problem relates to that, get back to me as I
    might be able to help.
    Rockit
    rockit, Jul 15, 2007
