gsxr exhaust
Discussion in 'Australian Motorcycles' started by Allan Gibson, Feb 16, 2006.
  1. Allan Gibson
    Allan Gibson Guest
    Trying to find a 4to1 system to suit a 89 750 gixxer, some body got one in
    the shed perhaps? lower case of course.
  2. Allan Gibson
    justAL Guest
    Call up the guys at MEgacycle and get them to make one up for you. The
    alternative is to see if you can get Yoshimura Japan to send one to you.
    justAL
    justAL, Feb 16, 2006
  3. Allan Gibson
    rockit Guest
    Not sure whether it's a J or a K that you are referring to?
    Plus you may know where you are at. My daughter has an L, I think that was
    similar to the K in many respects, and that L came with a std 4 - 1 system.
    Hers is the anniversary model, but I have seen other L's with the same
    system also.
    It may not be applicable, but I had an 1100 K, with a 4 - 1 ; don't know
    whether the pipes were megacycle, but the can was. Very difficult to change
    the oil on, the pipe went directly beneath the drain bung. There was a way
    to do it though. It was also necessary to disconnect one of the oil cooling
    radiator hoses so that the oil filter could be removed. It wouldn't fit
    between the header pipes.
    Rockit
    rockit, Feb 16, 2006
  4. Allan Gibson
    GB Guest
    Yeah, that upper case email address will fool the spammers
    for sure!
    GB
    GB, Feb 17, 2006
