Guzzi Battery
Discussion in 'Australian Motorcycles' started by The Happy Drunk, Sep 9, 2009.
  1. Since I've had the Breva it's has occassionally had trouble starting.
    Today, I took it back to the shop and they're replacing the battery
    and checking all the connections while they're at it.
    I was thinking of investing in a battery saver/charger, but having
    never used one, I know nothing about them.
    Does anyone here use them and if so, what brand/model and what do you
    think of them?
    On another note my loaner bike is a Ducati GT1000 ..... that was fun,
    but I don't think I would own one.
    __
    Cheers
    The Happy Drunk
    Breva 750
  2. The Happy Drunk
    atec 7 7 Guest
    All you need is a low amperage electronic top up unit , 1 am or less
    will do it , then fit a suitable plug to the battery for a quick release
    any brand including cheap asian will do it
    atec 7 7, Sep 9, 2009
  3. The Happy Drunk
    gwd Guest
    Batterys don't like being allowed to go flat, so a battery minder can
    pay for itself pretty quickly.
    Battery world sells one for less than $50 that senses the state of
    charge and applies appropriate charging current from zero amps to 2
    amps in 3 steps. It comes with a variety of connectors.
    BMW has a sophisticated one that can be used to recharge a flat
    battery, but it has a BMW price tag.
    I bought an expensive one, but in hindsight I don't think the expense
    was justified - the cheaper ones seem to be pretty effective in
    practice.
    Don't be tempted by el cheapo fixed current types though. Overcharging
    can ruin a battery too.
    YMMV
    gwd, Sep 9, 2009
  4. I have a Kawasaki ZX12R, and live in Cairns and at times my motor cycle sits
    in the garage for up to six weeks without being used.
    When I have a new battery in it, no problems, but after some time of these
    periods of non use (about a year) I find that the starter motor cannot start
    it when it is hot and it needs to cool down a bit before it will start
    again. I figure that the battery is sulfating up during these periods of non
    use, and then does not have the power to start the bike.
    Had a new battery fitted around six months ago and had a CBE 350 ma battery
    charger fitted to the bike.
    It is a plug pack type charger and comes with a special plug on the DC
    (Battery) side which half of which is permanently wired to the battery, so
    once it is in the garage all I need you do is connect up the charger to this
    special plug and connect the battery charger to the mains, two seconds work.
    So far no problems and the bike is starting OK when hot.
    Time will tell I guess.
    RamRod Sword of Baal, Sep 9, 2009
  5. From memory I think the charger cost around $73.00
  6. The Happy Drunk
    VTR250 Guest
    Hi,
    I had a battery die on me one winter and, when reading up on it I
    found out that a trickle charger helps extend the life of the
    battery. How much depends on how the battery gets used. For example
    it can help avoid deep-cycling the battery.
    Mine cost about $80 and it has a tamiya connector half way along the
    wire. I have a choice of two ends. One set can be screwed to the
    battery terminals and becomes a permanently attached plug on the side
    of my motorcycle. The second lead, (which I also use to charge other
    lead-acid batteries) ends with a pair of crocodile clips (handy for
    charging a mate's bike). The charger's been powered on for several
    months at a time over the last 3 years and I'm glad I bought it. I
    would have done more bump starts without it.
    VTR250, Sep 9, 2009
  7. The Happy Drunk
    Nev.. Guest
    If the battery was on the way out, it was on the way out. If you ride
    the bike regularly, there's probably nothing to be gained by using a
    battery saver. I think the real battery killer is when you ride the
    bike infrequently and let it sit idle for weeks or months at a time. if
    you ride it weekly, I doubt you'll see much fluctuation in the voltage
    which would shorten its life noticably.
    Nev..
    '08 DL1000K8
    Nev.., Sep 10, 2009
  8. I agree with that logic.
    The reason I'm doing research and considering a battery saver is due
    to some advice from a Guzzi forum. I was told that the small blocks
    (750cc etc) don't provide a good charge below 4000rpm, which I thought
    was a strange design feature, but having only owned the Breva for a
    couple of weeks and having next to no experience with them ..... who
    am I to argue.
    I figure that even though I will be riding most days, 4000rpm is
    around 100km/hr and if what I've been told is true then I will be
    experiencing the problem again ..... Unless I find some other
    information in the near future, some extra "insurance" can't hurt.
    I personally think good charge would be occuring below 4000rpm......
    __
    Cheers
    The Happy Drunk
    Breva 750
    The Happy Drunk, Sep 10, 2009
  9. In aus.motorcycles on Thu, 10 Sep 2009 19:34:15 +1000
    Umm.. remember that bit about Guzzis love revs?
    Change down now and then :)
    No, can't hurt to have a charger, but just give it stick every few
    days and it should be fine.
    Zebee
    Zebee Johnstone, Sep 10, 2009
  10. Were these people refering to 70's model small blocks?
    Poor charging at low revs was a problem with Ducati GT 750 and Sport models
    of that era. 150 watt (optimistic claimed ) alternators were the culprit.
    I don't know, but I suspect modern Guzzi's would have improved vastly in
    this and many other areas.
    Why not check the output with a voltmeter across the battery terminals
    whilst reving the motor at a standstill?
    Look to see at what RPM to voltmeter reads 13.5 volts or higher, should
    never reach more than approx.14.5 though
    I'd hope that even with the headlight on, probably manditory, it will be no
    more than 2500 RPM.before the voltmeter reads 13.5
    Capt. A. L.
    Capt About Lunchtime, Sep 11, 2009
  11. No, the person making the comments was queried and he said the current
    750's have the problem.
    __
    Cheers
    The Happy Drunk
    Breva 750
    The Happy Drunk, Sep 11, 2009
  12. ">>
    Oh dear if this is indeed the case I think MG may be taking the retro theme
    to extremes. I find it laughable that even with the guidance and technical
    expertise of Aprila the electrics appear to be still 1973 std.
    Ducati, Triumph and even HD have lifted their game in this area what gives
    with Guzzi?
    Still if the bike rows your boat a battery charger is a small price to pay,
    I've put up with much more, and still do for some.
    Capt. A. L.
  13. The Happy Drunk
    theo Guest
    My wife has a Toyota RAV4. Never a problem starting, battery is seven
    years old. I got her a Jeep to replace it. No start on the RAV4 for
    three days. Won't start, battery's fucked. $132.- C'est la vie.
    Theo
    theo, Sep 11, 2009
  14. The Happy Drunk
    Nev.. Guest
    Had a similar experience in my car a few years back. Didn't start the
    car for a month while i was overseas, came home and it started first go.
    Following day the battery it wouldn't even
    Nev..
    '08 DL1000K8
    Nev.., Sep 11, 2009
  15. The Happy Drunk
    Nev.. Guest
    ....turn the engine over. New battery required.
    (Hate it when my news reader sends whie I'm still typing...)
    Nev..
    '08 DL1000K8
    Nev.., Sep 11, 2009
