I've got a '94 Moto Guzzi California 1100i, fuel injected that I've had for about 4 years. It has also been modified for twin plugs. About a year after I got it, it started `missing` slightly. At first it was barely noticeable but over a period of weeks it got worse till it would intermittantly run on just one cylinder. I gave it to my mechanic who managed to get it running again, but has since said he is not sure what the problem was. Anyway after two years with no problems it has started doing it again. I have pulled the side covers off and sprayed the leads that go into the finned box on the left hand side. (about this point most of you will be getting an idea of my mechanical aptitude) On the right hand side I have pulled and sprayed the six relays and rotated them one position clockwise because according to my mechanic all the relays are identical. I have pulled the outside spark plugs, the only ones easily accessible and they were BLACK with a fair build up of soot. I say soot because a lot of it just wiped off. I have pulled, cleaned and sprayed the leads coming out of the coils. After all that it will run fine for maybe half and hour then start missing again on one cylinder. Any ideas I can try please.?
