Guzzi Quota at 20K miles of ownership
Discussion in 'UK Motorcycles' started by Pip Luscher, Aug 12, 2005.
  1. Pip Luscher
    Well, £135 poorer, I have my commuter/tourer back. It took both a new
    ignition relay - a special fused two-pole jobbie that motor factors
    don't sell, and yet another exorbitantly priced Ducati voltage
    regulator after the last one went phut last week.
    I expect I'll keep both the old regulators: the first is useful as a
    check/emergency unit and the second has softer potting compound which
    I will, in time, dig out in order to reverse-engineer the damn things.
    That's also at least the second relay I've replaced. Both the
    regulator and these relays are best regarded as slow consumables, it
    seems.
    Thinking about it, to date this bike has eaten:
    two voltage regulators, well, the original still regulates but the
    warning light stuck on and the potting compound is cracked; the second
    one just died completely;
    four oil pressure switches - the current one is "resting";
    one fuel level sensor - found that out the hard way: still not fixed;
    two stainless-steel exhaust collector boxes - both cracked, both
    welded, then the baffles worked loose and started rattling in both;
    one battery - though that was probably due to too many short journeys;
    and finally two clutch cables.
    Plus all the usual consumables, of course.
    For all that, still my preferred commuter. It's not anywhere near as
    manically fast as the TL but it's just... pleasant. Corners are just
    as much fun and there's less frustration with the morning A14 crawl -
    I tend to look upon the slow cages with a more benevolent eye.
  2. Pip Luscher
    JB Guest
    If you can spare one, I'll get one depotted and the circuit drawn
    up/re-engineered with more robust components.
    Possibly caused by regulators 'failing'? These are pretty prone to voltage
    transients which are often present when regulators start failing.
    I'd dearly love a Quota, but I'm far too short in the leg I reckon. My Spada
    is 'just right' and so is the FJ1100. I did managed to lower my old
    roadgoing KX500 rear linkage so I could actually reach the ground and still
    keep a good degree of travel, so I suppose I could do the same with a Quota.
    cheers,
    JB
    JB, Aug 12, 2005
  3. Pip Luscher
    Well, if you're really looking for a project then I'll send the
    totally buggered one, however, I'd be interested in doing it myself if
    not.
    My main concern was working out whether it was a series or shunt
    regulator, but actually I could work that out simply by measuring the
    input & output currents.
    I think it's just a switch.
    On paper, the 1100 is a better bike with improved brakes, projector
    headlights, re-tuned engine and lower seat. They do seem to be rarer
    that the 1000s though.
    Tallbloke is selling his 1000...
  4. Pip Luscher
    JB Guest
    Only curious. I do like to play around with the scope and Protel in the
    coming winter evenings.
    Probably series I'd have thought, but possibly even a high efficiency
    switcher these days. cheaper to priduce and much more efficient.
    they still don't like high energy transients. Just like relay coils.
    Projector headlights. Ewwweee. Though I do prefer the 1100 engine. This is
    the injected one, yes?
    <perk> mind you, I'd never touch the bloody ground.
    JB
    JB, Aug 12, 2005
  5. Pip Luscher
    Hmm. Hope the ECU is well protected.
    AFAIK only the very early 1000s weren't. Mine certainly is.
    Pip Luscher, Aug 13, 2005
