Haiti
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jan 16, 2010.
  1. Wicked Uncle Nigel
    On Mon, 8 Feb 2010 11:48:59 -0000, "'Hog"
    snip>
    Really?
    You're not diving in the right places.
    Andy Bonwick, Feb 8, 2010
  2. Wicked Uncle Nigel
    'Hog Guest
    Many of us are daft but very few of us are daft enough to dive in caves
    ITYWF
    'Hog, Feb 8, 2010
  3. Wicked Uncle Nigel
    Then you're missing out on a whole new experience. Not all caves are
    restricted and dangerous but they all teach you to be able to dive in
    braille.
  4. There are two types of students I've been involved with trying to train
    divers:
    1/ The cocky I don't have to pay attention I can do anything.
    2/ The nervous / worried / scared who listen to everything I tell them.
    It's the second sort that don't get them selves into trouble as often.
    [FX]
    Following group of students in an open water dive.
    1, 2, 3, 4 ,5 er? 6 where is 6 oh sh*t he's on the surface again.
    [/FX]
    Mick Whittingham, Feb 8, 2010
  5. Wicked Uncle Nigel
    boots Guest
    If nothing goes wrong. There have been fatal injuries in less than a
    couple of metres.
    boots, Feb 9, 2010
  6. Wicked Uncle Nigel
    'Hog Guest
    I refer Sir to the comments between Champ and myself. Diving is fun in
    bright clear warm water with lots of fish and coral.
    I admit caving is frustrating when the fun is halted by water and we free
    dived up to about 20ft, but the water was crystal clear.
    'Hog, Feb 9, 2010
  7. Wicked Uncle Nigel
    'Hog Guest
    I did mention Darwin and swimming pools
    'Hog, Feb 9, 2010
  8. Mate I was working with about 20 years ago went diving in the
    Nullarbor Desert here in Oz. Yes, there is a massive cave system under
    the desert. While the team were down there it flooded through (I can't
    recall the exact details now). They were trapped down there for 2-3
    days. He was shooting the dive for the video production company we
    were working for at the time. I think they were going for a record for
    the longest cave dive or something. They were lucky to get out alive.
    There's quite a bit of broadcast camera gear (admittedly somewhat out
    of date now, but worth probably $100k back then) sitting in a hole in
    the middle of Australia.
    I don't mind cave diving, but I think that experience would put the
    wind up me somewhat.
    Kevin Gleeson, Feb 10, 2010
  9. Wicked Uncle Nigel
    boots Guest
    TBF I reckon it's more fun in dark cold water than warm blue water
    with loads of fish. If I had to give up one or the other it would be
    warm water diving that got the push.
    boots, Feb 10, 2010
  10. I agree. The waters off the East Coast of Tasmania for instance. Beats
    the hell out of the Great Barrier Reef or Fiji for me. Yeah, you need
    a semi-dry suit, but such a variety of experiences and clearer water
    in general as well. Never got to go for a dive in UK, but water temp
    would be similar, maybe a bit colder, than Tasmania. But find the
    right places to dive and cold water dives win.
  11. Wicked Uncle Nigel
    'Hog Guest
    It isn't that I mind the cold but I hate all the extra gear and restriction.
    'Hog, Feb 10, 2010
  12. Wicked Uncle Nigel
    boots Guest
    Not sure what it is in Tasmania. Current UK sea temperatures will be
    around 7 or 8 degrees in the south[1]. Viz is variable but probably
    averages at 3 or 4 metres, seen 30 plus a couple of times and also
    less than 30cm. Drysuit every time in the UK for me, unless I know the
    sea temp will be above 20, preferably 25 I'd take it to foreign as
    well these days.
    [1] Finished a course 2 weeks ago using inland sites 3 - 5 degrees.
    That was a tad too cool for me after a while.
    boots, Feb 10, 2010
  13. Good gear (like any sport) should't find any more restriction really.
    I wouldn't do an open water dive off the Great Barrier Reef wihout a
    wetsuit on, yes a much lighter suit than Tas, down to just a lycra
    suit to stop coral scatches or stings from jellyfish. A good suit is
    hardly noticeable I've found. I think we are going to have to agree to
    disagree on this one :)
  14. Depends where you are.
    I've been in turbulent stuff where viz is nil. I've dived in waters in
    Tas where viz is 45m.
    Water temp is normally ranging from min of around 10C to max around
    18C. We get some upswells from the Antarctic that might drop it to 8C
    but that is rare.
    I have done some freshwater dives at 4C though. I was young and doing
    it in an old 7mm single suit wetsuit, with a hole in the crotch. Every
    time I kicked the fins it sent burst of nearly freezing water onto my
    balls. Oww, oww, oww. Maybe that explains why 30 years later I don't
    have any kids?
    (Apart from not wanting any of the little buggers).
  15. Oh - btw, 3 degree water doesn't exist unless someone added alcohol to
    it. It stops at 4C then the next phase change is ice.
  16. What? Surely the freezing point of normal water is 0 degrees C, and
    lower still for salt water?
    doetnietcomputeren, Feb 10, 2010
  17. Wicked Uncle Nigel
    The thing about pure, distilled water is you don't often come across
    quantities of it big enough to go diving in.
    ogden, Feb 10, 2010
  18. Nope there is a point where it has to drop energy to go through the
    phase change to ice. I don't have links and can't be arsed looking,
    but seawater will only go to 4C. Th energy to do the phase change is
    worth those other 3C. Google it. I'm sure it is out there somewhere.
    Not sure whether the same is at the other end (ie 100C) but as I am
    fucked if I am going to dive in boiling water, I really haven't
    researched that end :)
  19. doetnietcomputeren, Feb 10, 2010
  20. Wicked Uncle Nigel
    M J Carley Guest
    Naaah.
    Sea ice begins forming in the northern Bering Sea as late as
    November, as the ocean reaches a temperature of -1.7°C, the freezing
    point for saltwater in this area, ...
    http://www.beringclimate.noaa.gov/essays_mcnutt.html
    As it happens, you can get pure water down to about -40C before it
    freezes, if you're careful.
    M J Carley, Feb 10, 2010
Similar Threads
Loading...
