Haiti
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jan 16, 2010.
  1. NIMBY situation and I wouldn't want to live next to one, or a coal
    station or a wind farm.
    As someone else pointed out, the worse industrial disaster (yeah - OK,
    after British Leyland - I did like that line) was Bopal.
    Get a space elevator going and eject the waste away from Earth and
    I'd be happy. Cold fusion and go for it. But even without either of
    those technologies, I think we are seriouosly going to need to go
    nuclear even if my heart ain't really in it.
    Kevin Gleeson, Jan 19, 2010
  2. Wicked Uncle Nigel
    Switters Guest
    Agreed, Collapsium is the best in the series, the ideas are great and you
    can't fault the physics behind it. Not when he writes it all down.
    It's one of my favourites along with Stross' Accelerando and Reynolds'
    Pushing Ice.
    Switters, Jan 19, 2010
  3. Hence I divided up my classifications into short, long and very long.
    Oooh I like that word!!!!
    At least you discuss things, which is an admirable trait!
    Don't forget the solar cycles and the effect on the solar wind/flares.
    That is now believed to have a greater effect on short term climate
    change than before.
    Heliosat family and the old Magnitosat now replace by part of CHAMP's
    mission (not our Champ) and SWARM to thank for that data.
    It's not the trigger that gets you it's the bullet!
    As I said it has its own natural cycle.
    ?? That would upset a lot of Satellite Guys I worked with not to mention
    NOAA who do a very fine job in that direction.
    That's the temperature into the Caribbean and Gulf area of the Global
    Conveyer. It has risen significantly and is the cause of the intensity
    of hurricanes in the last few years. The Atlantic conveyer has tended
    toward the East Coast of the States as well. (A possible cause of ice
    melting naturally?) The temp of what's left to transit the Atlantic
    hasn't changed anywhere near as much as in the Caribbean area.
    Surface and deep water buoys do a fine job in that direction and is
    backed up well by SPOT and NOAA's Sats.
    Historically it can be done by its effect on the global weather.
    Recorded in historical manuscripts and data derived from core samples
    both ice and sea bed, coral growth in warmer latitudes etc.
    If it does happen in my life time, I'm moving somewhere warmer.
    Ohh the water gets muddier:
    http://www.express.co.uk/posts/view/152422/The-new-climate-change-scandal
    OK I know it's the Express but I can't find the original. I think it
    was in Science Today or it sound like that.
    I thought Pachauri and the IPCC were brighter than that. I know Gore
    isn't.
    Smacks of Tony, his WMD and 45minute being based on a student's
    scribbling 10 years before.
    You may have been closer to the truth, than you thought, with your
    original inclusion :eek:)> :
    Tomorrow at the IPCC:
    Rajendra Pachauri: "Great work on climate change guys, but we've got a
    question: there are some things called ''Milankovitch cycles'', did
    anyone take account of them?"
    Scientists: "Shit! No! This changes everything!"
    Rajendra Pachauri: "Also, did anyone work out how much of the change is
    natural variation, and what is man made?"
    Scientists: "Bugger, we knew we'd forgotten something."
    That sort of crass stupidity is unbecomming, Mick. ????????
    Mick Whittingham, Jan 19, 2010
  4. In 1980 I worked with an American guy who had worked on the reactor
    electronic control system for 3 mile island. The company he worked for
    had produced some prototype circuit boards that had been tested for a
    long time but ended up being installed to save costs.
    These control systems were the only thing that was keeping 'The lid on
    things' as it were.
    As he said to me when I asked was it in a safe state.
    "How would you feel about a control system now submerged with the water
    used to control the incident, basically built out of Radio Shack parts
    that is in a box not intended to be under water?"
    He also said the initial problem was made critical by the high pressure
    air and water 'snap on' connectors being the same type and the same
    colour and next to each other. An operator was told to clear a valve
    using a hose connected to the water line but connected it to the air. It
    was air pumped in that buggered up the pumps. I think I got that the
    right way round.
  5. Wind turbines
    Sea turbines
    Tidal dams
    Geothermal
    Big Solar stuff like the Sahara
    Develop low loss power transmission
    Loads of power sources around, we are just using the wrong sort.
  6. Wicked Uncle Nigel
    ogden, Jan 19, 2010
  7. Wicked Uncle Nigel
    Ben Guest
    Not changed to "within F's daughter's lifetime" yet?
    Ben, Jan 19, 2010
  8. Wicked Uncle Nigel
    'Hog Guest
    I'm with you on this one. The objections raised by the NIMBY's and the
    Greens to deep burial of radioactive waste was that miniscule possibility
    the geological activity *might* just possibly allow a few long half life
    particles to leach to the surface in 10,000 to 100,000 years. Seems like an
    absurd argument to me.
    Given the depth of the mines and the type of strata it is highly unlikely
    that even a huge earthquake would do so anyway. It will most likely be
    undersea tunnels in the UK anyway. And if a volcanic eruption comes up
    through it I doubt the locals will be concerned about the additional
    radioactivity.
    'Hog, Jan 19, 2010
  9. Wicked Uncle Nigel
    'Hog Guest
    I have more faith in them than you do then. But still, designs should be
    "idiot proof".
    Cooling systems that can maintain safe core temperature by convection and
    coolant/air heat exchangers alone.
    Suspended moderator rods that failsafe into the inserted position
    Tough containment vessels and enclosures
    Containment vessels with disaster scenario burst discs in the base
    Building the core suspended over a cup excavated from the bedrock so if the
    impossible does happen it dumps, is contained, eventually cools and can be
    concreted over.
    So, building a failsafe design but incorporating disaster scenario features
    as well.
    Funnily enough we don't hear any public speculation yet of what the
    consequences of a containment failure in a commercial scale Fusion Reactor
    would be. Despite the scale of R&D investment. Pretty fucking scary I expect
    and that's probably why they don't discuss it (in public).
    'Hog, Jan 19, 2010
  10. Wicked Uncle Nigel
    'Hog Guest
    Heh ok but you know we are talking about X00MW of GW class civilian nuclear
    power stations
    'Hog, Jan 19, 2010
  11. Wicked Uncle Nigel
    'Hog Guest
    *snort*
    'Hog, Jan 19, 2010
  12. Wicked Uncle Nigel
    'Hog Guest
    That's really fucked up logic. We live to consume, to enjoy, to sign out
    after a life of pleasure and excess. Possibly to provide the same for our
    children. Not to build a utopia for some far future generation.
    'Hog, Jan 19, 2010
  13. Wicked Uncle Nigel
    Beav Guest
    <casts line, and got one>
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 19, 2010
  14. Well that's why I made the ginge comment wasn't it. I didn't get to
    the UK til 2006 and late last night couldn't be arsed hunting around
    to see whether you guys had seen it. But figured you probably had.
    And just because another website says it _isn't_ true doesn't mean it
    is correct either.
    I'm inclined to go with the made-up story though. It just doesn't ring
    true. And as it is 1am on a weekday here I'm not going to go hunting
    more for info.
    I'm inclined to believe the bit I did read on that link though.
    Bedtime.
  15. Wicked Uncle Nigel
    'Hog Guest
    They invented it for themselves, not me. Selfish cunts all.
    'Hog, Jan 19, 2010
  16. Wicked Uncle Nigel
    I've had enough of dealing with the crap from yours.
    ogden, Jan 19, 2010
  17. Wicked Uncle Nigel
    Well of course, you had it tough.
    ogden, Jan 19, 2010
  18. Wicked Uncle Nigel
    M J Carley Guest
    M J Carley, Jan 19, 2010
  19. Wicked Uncle Nigel
    'Hog Guest
    It kinda skirts over "raping the wealth of the world so we could all have an
    easier life". Which seems like a good idea.
    'Hog, Jan 19, 2010
  20. Wicked Uncle Nigel
    Beav Guest
    Last I saw of him he was rescuing some tart in the jungle bordering
    Camaroon. [1]
    [1] Shit film, the title of which doesn't deserve a mention.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 19, 2010
Similar Threads
Loading...
