Handle bar engine kill switch or ignition key switch to stop bike?
Discussion in 'UK Motorcycles' started by Guest, Oct 19, 2009.
  1. Guest
    Pete Fisher Guest
    The sort that lets you get all that nice, fresh oil reaching the parts
    it needs to after a filter change before starting the engine. Many
    Italian thoroughbreds of the 90's - et Voxan (well up to 2003)
    naturellement!
    | Pete Fisher at Home: |
    | Voxan Roadster [ SPACE ! ] Yamaha WR250Z |
    Pete Fisher, Oct 19, 2009
  2. Guest
    Definitely not. No Kawasaki I've ever ridden has spun the starter
    with the kill switch off.
    Yes, 70s (and maybe 80s) Hondas used to do it.
    Champ, Oct 19, 2009
  3. Guest
    4ax.com:
    Unknown to me, my 93 Honda Dominator did it. I must've knocked it off when
    washing the bike. Took a while to discover why the bike wouldn't start...
    wessie, Oct 19, 2009
  4. Guest
    crn Guest
    The GS500 also does that.
    Cue much cussing and general anger until realisation dawns.
    It took several incidents to train me into the habit of checking the
    kill switch as part of every start.
    crn, Oct 19, 2009
  5. Guest
    Guest Guest
    thanks for the suggestions.
    I'll go have have a look at the Triumph forums the other chap mentioned. I
    had loads of trouble with my 1976 T140, and bought that new, I was warned
    not to buy this new stile bonneville, but I knew best.... I wan't another
    Guzzi now I would like a bit of a ride out next summer!!! I have a Honda 90
    step through 70k on clock and its never, no not ever, let me down....
    Guest, Oct 20, 2009
  6. Guest
    DozynSleepy Guest
    Pip Luscher wrote:
    snip
    Was this the lurid green one that was advertised a while ago with low
    mileage due to an intermittent electrical fault ?
    Quite liked the look of it.
    DozynSleepy, Oct 20, 2009
  7. Guest
    Well I had the centre coil go on my 955i Sprint ST, which is
    essentially the same engine, AFAIUI, and I _never_ used the kill
    switch.
    So the correlation is looking a little weak, on that sample.
    Ace, Oct 20, 2009
  8. Guest
    IME plug top coils are feckin unreliable beasts, including on certain
    upmarket cages
    Hog, Oct 20, 2009
  9. Guest
    It's not the same as the T4s, which were 885 carb engines. Might be the
    same as the Bonneville but I know nowt about them.
    Krusty, Oct 20, 2009
  10. Guest
    Beav Guest
    I use the switch for one simple reason. If I have to remove the key, I've
    got to switch it off anyway, so why do two tihngs when one will do enough?
    Economy of movement. Coz I'm a lazy ****.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 20, 2009
  11. Guest
    Beav Guest
    Who said anything about the engine spinning over?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 20, 2009
  12. Guest
    Beav Guest
    And that doesn't work on most new bikes now. The fuel is cut off by the kill
    switch along with the spark so there's no build up of unburnt juice
    collecting in the pipes/cans.
    Fucking spoilsports.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 20, 2009
  13. Guest
    crn Guest
    Neighbour has had 2 replacement coil packs on his Agila.
    The AA bloke said they are a very common fault.
    crn, Oct 20, 2009
  14. Guest
    YTC#1 Guest
    Which is fair, as its not big and its not clever :)
    YTC#1, Oct 20, 2009
  15. Guest
    Dave Emerson Guest
    Post corrected. Those old Fords are always breaking down.
    Dave Emerson, Oct 20, 2009
  16. Guest
    Don't thinks so. It is (or was) a fairly lurid green but not the more
    common colour scheme with matched tail, tank and mudguard: this one
    has graphite tail & mudguard. I was a bit concerned at first: I
    thought that maybe the plastics had been replaced with mismatchd ones,
    but Google reveals that Guzzi did sometimes do V11s with the tank one
    colour and the rest in another.
    Intermittent faults on these are often down to the relays - it's a
    known fault. My other Guzzi uses different pattern relays but they
    suffer the same problem and need the contacts cleaning every couple of
    years.
    I found that the clutch switch and/or its wiring is a weak point as
    well: I've simply shorted it out for now.
    Opinions seem to be mixed: some like them, some think tthey're ugly.
    They're certaInly characterful.
    I sat on one several years ago and I've wanted one for some time. The
    one I've bought is extremely rough in comparison, but it was
    /relatively/ cheap. I suspect not in any way a bargain though.
    Pip Luscher, Oct 20, 2009
  17. Guest
    I feel the same when people refer to BMWs as an E-number.
    CT, Oct 21, 2009
  18. Guest
    Jim Guest
    A T4 is a surf van for chavs, anyway.
    Jim, Oct 21, 2009
  19. Guest
    Francis Guest
    Yes, relays are the usual suspects.
    My 1999 V11Sport used el cheapo Siemens relays that were a real PITA.
    Once replaced with OMROMS, no more problem to start.
    Do the same to the sidestand switch (plug is under the tank, left side).
    You should verify the side brackets of the oil cooler, the 1999/2000
    models were in shit alloy that breaks due to the vibrations, replaced
    since 2001/2002 with steel.
    Francis, Oct 21, 2009
  20. Guest
    Beav Guest
    Not loud either:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 21, 2009
