Handle bar engine kill switch or ignition key switch to stop bike?
Discussion in 'UK Motorcycles' started by Guest, Oct 19, 2009.
  1. Guest
    Beav Guest
    And on low end of the market shitters too. Coil packs are probably the
    single worst idea anyone ever came up with.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 21, 2009
    #41
  2. Guest
    Tim Guest
    What Tn were the 885-FI ones?
    Tim, Oct 21, 2009
    #42
  3. Guest
    Yep, some of these at least were Siemens.
    Ah, that is a useful way of identifying its actual age: it was
    registered in 2001.
    Pip Luscher, Oct 21, 2009
    #43
  4. Guest
    Good point well made. Too much time spent in Tiger groups I s'pose. T4s
    were the first generation Tigs, 885cc with carbs. 1999 was the first
    year of the 2nd generation (EFi, T7).
    Krusty, Oct 22, 2009
    #44
  5. Guest
    T7, same as the 955i.
    #45
  6. Guest
    Francis Guest
    First batch (1999-2000) got the shorter frame without the braces between
    porkchops and the lower back of the crankase.
    On some of them, there is a trapezoidal plate under the main frame to
    link it with the top of the clutch housing.
    It improves the rigidity of the frame/engine/gearbox and prevents cracks
    in the gearbox case near the point where it attach to the frame.
    In 2001 they switch to the new frames with the lower brace, and removed
    the top plate.
    In 2000 and 2001, they used the leftover old frames without the braces
    but remove the top plate, and old engine casses that cannot receive said
    braces with new frames (without top plate) : all these combinations lacks
    rigidity and the gearbox case usually crack and oil seep at the back...
    avoid if possible.
    1999/2000/2001 were recalled by Guzzi under warranty for important
    modification: rods and rod screws (prone to break in case of sustained
    high revs...), and gearbox parts. You should verify at a Guzzi official
    dealer if your bike is concerned (frame number) and if it was done.
    You'll find a lot of info (workshop and user manuals, part lists, wiring
    diagrams, factory videos, etc) on www.guzzitek.org.
    Mine: http://www.bete-des-vosges.org/Visible/V11s-2.0/V11S_2.0_01.jpg
    Francis, Oct 22, 2009
    #46
  7. Guest
    Guest Guest
    my naughty bad lazy **** of a Bonneville is twin.
    I wanted a bike that suited me. I've got a right idle fucker that won't get
    out of bed and never goes anywhere...
    Guest, Oct 22, 2009
    #47
  8. Guest
    Tim Guest
    Thanks.
    Tim, Oct 22, 2009
    #48
  9. Guest
    Heh, wonderful and highly descriptive.
    [snip loads of useful stuff]
    Thanks for all that. I still need to check for the mods but it's one
    of the later 2001 one by the look of it, with the lower bracing bars.
    There seem to be a lot of French sites for these: in fact the first
    wiring diagram I found online was French. Were they particularly
    popular over there?
    Smart. What's the exhaust?
    Pip Luscher, Oct 23, 2009
    #49
  10. Guest
    Beav Guest
    It's a gathering of tubes to let hot gas escape at the back of a bike, but
    that's another story.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 24, 2009
    #50
  11. Guest
    No, no, NO! It's "...but that's not important right now."
    Pip Luscher, Oct 24, 2009
    #51
  12. Guest
    Beav Guest
    I'm getting far too old for these quotes :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 25, 2009
    #52
  13. Guest
    Francis Guest
    For Guzzi value of very popular, yes. :)
    A lot of owners see the V11 as "the last classical Guzzi".
    AFAIAC the real classical are the Tonti frame Guzzi, others will put the
    limit at the horizontal single 500.
    To each his own.
    It is a early Quat-D, without cat and "not for road use".
    They no longer sell that model, it is a bit throaty above 6000 rpm.
    Francis, Oct 27, 2009
    #53
