Handling
Discussion in 'UK Motorcycles' started by Jeremy, Oct 3, 2005.
  1. Jeremy
    Jeremy Guest
    The Sprint seems to be far more sensitive to grooves in the surface,
    white lines etc. than the Fazer was. It is actually somewhat
    disconcerting and is deifinitely reducing my cornering confidence.
    The bike has 7k miles and a pair of what would appear to be little-worn
    BT010s. Pressures at the moment are 30psi front, 42psi rear.
    Any suggestions on what to check?
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Oct 3, 2005
  2. Jeremy
    dwb Guest
    Check the Bridgestone website - 30 in the front sounds a little low.
    dwb, Oct 3, 2005
  3. Jeremy
    Daz Guest
    I would have thought the front should be more like 36. A flat front
    will make the front feel like it's running *in* rails and not wanting
    to turn. IMLE though this is only noticable when you have a silly
    amount of font tyre pressure like 20psi or less. Might still be worth
    looking at.
    Daz, Oct 3, 2005
  4. Jeremy wrote
    Tyre pressures, the suspension, the rider, the cat, all the usual shit.
    I have a feeling though that this pursuit of quick steering and tyres
    that only grip on the side and all that stuff has led to a bit of over
    radicalisation in profile design. I think there is a good argument for
    fitting flatter profile rubber, especially for lardy old tourers.
    steve auvache, Oct 3, 2005
  5. Jeremy
    tallbloke Guest
    And the rear sounds too high as well.
    Have you checked for wheel bearing play?
    Swinging arm bearing adjustment?
    The big Triumph I had a go on also felt a bit flighty on grooved tarmac,
    mebbe it's just the price you pay for a fairly quick handling setup...
    tallbloke, Oct 3, 2005
  6. Jeremy
    Jeremy Guest
    I should have been clearer - it's the back that feels "wrong".
    Bridgestone site doesn't list a rear but for the front it says:
    Front IPC :
    Front dimensions : 120/70 ZR 17 (58W) TL
    Front Profile : BT-010 J
    Front Pressure : 25.0
    So according to that, it's a little high. The book says 36psi front, 42
    rear. So as you say, a little low.
    jeremy
    Jeremy, Oct 3, 2005
  7. Jeremy
    Well, as others have said, the front is a bit low, so I'd check the
    manuel and adjust that. As to whether it would provoke said response,
    I wouldn't be at all surprised.
    I always found mine to be very sensitive to part-worn or
    incorrectly-matched tyres and it would then be very sensitive indeed
    to any slight variation in road surface. Going over the tramlines in
    Basel was a nightmare. Still, it's one more challenge ;-)
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Oct 3, 2005
  8. Jeremy
    tallbloke says...
    Not really. The ZZR1100, which weighs about the same, is 42 front, 42
    rear.
    Lozzo, Oct 3, 2005
  9. Jeremy
    tallbloke Guest
    Wow, surprising.
  10. Jeremy
    Jeremy Guest
    That'll be corrected before next outing.
    How did you find its stability and tracking of line through bends when
    the tyres and pressures were spot on?
    The feeling of unease is definitely limiting me - I was expecting
    something actually more poised than the Fazer.
    jeremy
    Jeremy, Oct 3, 2005
  11. Jeremy
    tallbloke says...
    It always struck me as odd, but I never had a any handling problems with
    any of my ZZRs when I ran them at those pressures.
    Lozzo, Oct 3, 2005
  12. Jeremy
    Eddie Guest
    Have you checked what units the Bridgestone site is using? I don't think
    it's psi...
    Eddie, Oct 3, 2005
  13. Jeremy
    Ahh. That'l be a fucked rear shock then. Mine went after about 15000
    miles, IIRC, which made for, err, interesting times. I remember
    completely fucking up one bend on an early botafot when mine was
    offering no damping whatsoever. Just trying to remember who was behind
    me at the time...
    That's not lb/in**@ though - it'll be kg/cm**@ or whatever that there
    other measure is.
    36psi is correct for the front, and it may well still be the cause,
    even if it feels like it's the rear that's odd.
    _______
    Ace, Oct 3, 2005
  14. Jeremy
    It had a very slight tendency to weave in very fast sweepers if you
    weren't spot on with throttle control. Easing off the gas tended to
    induce a bit of a forward/backward wobble on occasion. But that could
    be dialed out with suspension settings.
    I got so used to it that I didn't feel like it minited me at all,
    although my corneringlines were sometimes downright strange when
    running on worn boots. But it's never going to handle like a gixxer -
    apart from the weight of the thing, the suspension units just aren't
    up to the job and have very limited adjustment.
    Still, as I say, when it comes right, it can be very good, as I found
    by chance when I had to carry AndyB down from Luxembourg to my place
    through the Vosges mountains. I just cranked up both the the rear
    settings 'a bit' and it seemed to get it just right, so maybe careful
    tweaking by SWK could get it just right all the time.
    _______
    Ace, Oct 3, 2005
  15. Jeremy
    What are these "tyre pressures" of which you speak?
    ogden, Oct 3, 2005
  16. Jeremy
    Jeremy Guest
    I guess it's possible however:
    1) we've just 7k on the clock
    2) I fear the speeds involved were hardly those that might put much
    pressure on the shock (or perhaps this is irrelevant) - we're talking
    60-70 mph (yes wuss speed) gentle bends. But with a none-too-great
    surface it has to be said.
    jeremy
    Jeremy, Oct 3, 2005
  17. Jeremy
    Jeremy Guest
    Well the above was copied/pasted from the site - it says 25.0 clear as
    day (but doesn't specify the units).
    jeremy
    Jeremy, Oct 3, 2005
  18. Jeremy
    I have a spreadsheet that records the household expenditure and it says,
    as clear as day, I have £1,000,000 in the bank account.
    It doesn't mean it's right.
    sweller, Oct 3, 2005
  19. Jeremy
    What's it actually like with 36psi front and 42 rear, as suggested, is it
    any better?
  20. Jeremy
    Jeremy Guest
    Too busy posting to usenet to be able to ride it. Also am on a business
    trip until late Wednesday and have a really tight schedule Thursday so
    can you wait until the end of the week?
    jeremy
    Jeremy, Oct 3, 2005
