Handling
Discussion in 'UK Motorcycles' started by Jeremy, Oct 3, 2005.
  1. Jeremy
    dwb Guest
    You go and put 25 psi in your tyre and let us know if it's any better.
    Then, for a laugh, try 36 and see if it's any different.
    dwb, Oct 3, 2005
  2. Jeremy
    Jeremy Guest
    Per original post, the handbook says 36psi. I was just saying "the web
    site says 25" that's all ;)
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Oct 3, 2005
  3. That Nigerian bloke's mail arrived then?
    Grimly Curmudgeon, Oct 3, 2005
  4. Jeremy
    Tim Guest
    Those psi figures don't quite sound right. I'd go and get the "book of
    lies" but it's in the garage and I've started on the wine.
    Tim, Oct 3, 2005
  5. Jeremy
    The Drifter, which weighs about the same, is 28 front, 28 rear.
    platypus, Oct 3, 2005
  6. Jeremy
    Is that wheels-up or wheels-down?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Oct 3, 2005
  7. Jeremy
    Wheels-down, obviously. The pressure is automatically bled off as soon as
    the wheels are retracted - you don't want full pressure in the tyres at
    cruising altitude.
  8. Jeremy
    Good point, plus the lower ambient pressure at altitude would more
    than compensate for pressure drop withing the tyre.
    _______
    Ace, Oct 3, 2005
  9. Jeremy
    Beav says...
    You were told wrong.
    The 010 is more of a sports tyre, as opposed to the 020 being a sports-
    touring tyre. Typically an 020 will last longer at the expense of
    outright grip. The 014 is said to replace the 010, but most users seem
    to think the 014 is a much better tyre that grips better and doesn't
    wear at a much greater rate than the 010.
    Lozzo, Oct 4, 2005
  10. Jeremy
    Reckon so. Mind, I was running it on Avon Venoms with 30/36, which seemed
    to make it a bit livelier in the corners.
    platypus, Oct 4, 2005
  11. Jeremy
    MikeH Guest
    Deliberate choice of word?
    MikeH, Oct 4, 2005
  12. Jeremy
    You weren't with us at Chimay, I presume.
    _______
    Ace, Oct 4, 2005
  13. Jeremy
    Daz Guest
    My bike has eaten two 014's in juat under 4k and IMO they don't offer
    particularly good grid.
    Daz, Oct 4, 2005
  14. Jeremy
    I'v got just over 3500km out of my current (and first) 014 rear, so
    perhaps 2300miles. But I've never quite worked out how you tell how
    grippy a tyre is, apart from not falling off, which I've managed so
    far, so they can't be all bad. They do feel like they corner slightly
    better than the 011/012 they replaced, but that could just be in my
    imagination.
    _______
    Ace, Oct 4, 2005
  15. Jeremy
    Daz Guest
    I can feel them moving around when I'm not particularly giving it
    beans and I expect a bit more from a tyre with a useful life of circa
    2k miles. I'm sure they're a perfectly good tyre but I'll be trying
    something else when they get changed next as the front will also need
    changing.
    Daz, Oct 4, 2005
  16. Jeremy
    Daz says...
    Did you ever use 010s? What's your opinion of their grip and longevity
    compared to 014s?
    Btw. I knew you'd respond, so you're not included in the "most users"
    bit I mentioned.
    Lozzo, Oct 4, 2005
  17. Jeremy
    Heh.
    "Get your NEW Brideglopelin square section tyres now! Eliminate
    embarrassing chicken strips and needless side-stand pivot wear and
    tear!"
    Pip Luscher, Oct 4, 2005
  18. Jeremy
    The shock on the Drifter was a bit post-modern: the spring was barely
    adequate for solo on full preload, and the damping was a bit wet.
  19. Jeremy
    Yep. TBF the Drifter was specced as a cruiser, not a serious motorcycle.
    The poor thing probably had the shock of its life when I put 350 miles on it
    on Day One...
    I used to have a Silverwing, which was another monoshock, but with air
    assisted front and rear. Didn't generate anything near as much shock as the
    Drifter.
    The Drifter saw very little pillion action, because the back end was too
    soft. The shcok compressed so much that there was very little suspension
    travel, and the handling (such as it was) went to ratshit. The pillion seat
    was great for strapping a bag to, though.
  20. Jeremy
    Ol' Lone Wolf built a front rack for his:
    http://home.freeuk.net/thewolf/drifter.htm
    platypus, Oct 5, 2005
