Happy bunny
Discussion in 'UK Motorcycles' started by Lozzo, Jul 26, 2009.
  1. Lozzo
    Danny Imberg - 1st in class in MRO Stocksport 600 at Brands Hatch this
    afternoon on his Daytona 675.
    Lozzo - had the 675 in a million bits yesterday and this morning
    sorting a misfire and then an overheating problem.
    I are a very happy bunny, that's the first win we've had on the 675.
    Lozzo, Jul 26, 2009
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    <applause>
    Glad you made it. Great result.
    Good lad!
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jul 26, 2009
  3. Lozzo
    I thought you'd gone quiet as pig flu had got you.
    Well done on both counts.
    wessie, Jul 26, 2009
  4. Lozzo
    Colin Irvine Guest
    Nice one.
    Colin Irvine, Jul 26, 2009
  5. Lozzo
    Jeweller Guest
    Well done you.
    You know this old BM I have. . .?
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo, R80/7, R100RT
    (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Jul 26, 2009
  6. Lozzo
    Greybeard Guest
    Hey Lozzo, Don't exaggerate.... the 675 only has 276,172 bits to start
    with....
    Approximately!
    Well done _that_ man! Good on yah! :eek:)
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Jul 26, 2009
  7. Lozzo
    zymurgy Guest
    I'm always happy/amazed when that happens ....
    Paul.
    zymurgy, Jul 27, 2009
  8. Lozzo
    Cab Guest
    congrats on a job well done.
    There were approximately 30 bolts left over...
    Cab, Jul 27, 2009
  9. Lozzo
    Simon Wilson Guest
    Coo, well done. What went wrong with the bike?
    Simon Wilson, Jul 27, 2009
  10. Lozzo
    zymurgy Guest
    Hey, always handy for spares ...
    Paul.
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, zymurgy
    Lightened for racing, see.
    Wicked Uncle Nigel, Jul 27, 2009
  12. Very well done.
    Grimly Curmudgeon, Jul 27, 2009
  13. Lozzo
    The misfire was a blocked 'tea-bag' fuel strainer in the bottom of the
    fuel tank, which means stripping the pump right down and cleaning it
    out. You can't see it even when the pump is out of the tank, and I
    wouldn't have known it was there had I not been told as it's completely
    hidden.
    The overheating problem is something that often happens with hard raced
    675s, they don't quite flow enough water to cool efficiently, but they
    need some kind of restriction in the flow to ensure that any cold water
    flowing through does take heat away with it. The problem is that if the
    thermostat is removed completely, the metal bits run even hotter even
    though the gauge shows cooler, because the water is running way too
    fast to actually cool anything and is still quite cool when it hits the
    temp sender. The cure is to drill a series of 4mm holes around the
    circumference of the stat and then replace it in the bike. It's a
    common mod done to quite a few 675 race bikes. Not all of them run this
    hot normally though, so you don't know it needs doing until you're
    running at top level.
    I've a feeling the bike may well have overheated once too many times
    before I did the stat mod, as it chucked water out of the header tank
    over flow pipe and all over Danny's leg on the final lap of the last
    race. it looks like the head gasket has blown and the cylinders are
    pressurising the cooling system.
    Lozzo, Jul 27, 2009
  14. Lozzo
    <applause>
    Bloody well done, mate.
    Champ, Jul 27, 2009
  15. <Scribbles note for when Street Triple goes tits-up out of warranty>
    What are the engines like, in terms of build quality, inside? Good
    stuff?
    Oh, well done, btw.
    The Older Gentleman, Jul 27, 2009
  16. Lozzo
    heh. Me too :)
    Champ, Jul 27, 2009
  17. Lozzo
    I've not had this one down any further than throttle bodies off,
    thermostat out etc. There's a lot of plumbing and electronics under the
    tank, but it all makes sense once you've done it a few times and things
    don't break easily. The only thing we've worn out is the dry-break clip
    from fuel pipe onto the tank, and even that doesn't go anywhere once
    it's cable-tied in place. It's never needed any proper engine work in 3
    years of racing[1]except for shims and they were done before Danny
    bought it so we've left them alone until the end of the season. Overall
    build quilty of the rest of the bike is top notch, the finish on the
    frame and cycle parts is incredibly tough, because we haven't managed
    to scratch it despite lobbing bare metal ratchet strap hooks over the
    tubes time and time again, and then pulling the bike down tight in the
    van.
    Thanks, it's nice when it all comes together right when the thing has
    been spread all over blankets on the pit-garage floor all evening and
    morning.
    [1] Two full seasons of 675 Challenge plus a few Manx GP and NW200
    races, and now Danny running it in MRO Stocksport 600s against a load
    of British Superstocks kids with Daddy's money to crash and burn.
    Lozzo, Jul 27, 2009
  18. Lozzo
    Simon Wilson Guest
    I've read of a few people busting off some part of the plastic fuel line
    from the tank (pump outlet?) resulting in having to buy some rather
    expensive replacement parts. I only had to lift the tank to fit the
    snotoiler, when/if I need to remove the tank completely I think I need
    to be uber careful.
    Simon Wilson, Jul 28, 2009
