Hard disc down
Discussion in 'UK Motorcycles' started by Switters, Feb 17, 2010.
  1. Switters
    Switters Guest
    Disc in one of my NAS devices appears to have died of sorts. It spins
    up OK but the heads (I think) are making hell of a noise when the disc
    is being accessed and the NAS can't see it.
    Problem is, it's a SATA disc and I've no other device that can take SATA
    discs, so I can't put it into the PC and run some diags.
    Any tips? Should I just get a SATA PCI card and bung the thing into my PC?
  2. Switters
    crn Guest
    Another ukrmer gets the inverse midas touch.
    Sounds like an epidemic.
    crn, Feb 17, 2010
  3. Switters
    prawn Guest
    Buy a new SATA disk, put it in the NAS device and restore from the backup
    you have made.
    prawn, Feb 17, 2010
  4. Switters
    Simon Wilson Guest
    Get one of those usb -> sata/IDE adapter thingies. Much cheapness from
    ebay, and a useful thing to have lying around. Mine's in use right now.
    Simon Wilson, Feb 17, 2010
  5. Switters
    Switters Guest
    :p
    I've not had an IDE disc fail and I've owned loads. Out of the 1 SATA
    discs I've had, it has now failed. Ergo, I should stick with what I've got.
  6. Switters
    JackH Guest
    What he said.
    However, if you did decide to learn the hard way on that one, this
    would help your cause no end: http://tinyurl.com/yzvmcgy
    JackH, Feb 17, 2010
  7. Switters
    Switters Guest
    Ah, the old backup taunt eh ;) In this case, it's not a problem as it
    is my backup device. However there are files on there I'd rather delete
    before I send it away for warranty replacement.
  8. Switters
    'Hog Guest
    <glares at HTPC in corner>
    You may be right ;o)
    'Hog, Feb 17, 2010
  9. Switters
    Cab Guest
    You could always try to give it either a quick sharp slap (palm to the
    disk) or try freezing it overnight (in two sealed plastic bags) and
    then plugging it in, to get your data back.
    The slap method worked for me once, main moons ago and I've "heard"
    that freezing does sometimes help [1].
    [1] But it didn't work for me recently [2]. I need to figure out
    another way of sorting it.
    [2] For a mate. Honest guv.
    Cab, Feb 17, 2010
  10. Switters
    prawn Guest
    Only one backup, eh? How very casual you are ;-)
    prawn, Feb 17, 2010
  11. Switters
    Colin Irvine Guest
    The disk is probably FUBARed.
    I got a USB SATA caddy from Novatech for about £18. Works fine.
    Colin Irvine, Feb 17, 2010
  12. Switters
    DozynSleepy Guest
    That looks great. I've got a Team Xecuter X360USB USB to sata adapter
    but still need to faff around with power for the drive.
    Not sure the diagnostics for the sata drive would work through the USB
    adapter. Was unable to diagnose a faulty drive I had with my one. Mind
    you, even the onboard sata controller on my server didn't work with that
    drive.
    Seems to be worried that some confidential stuff might still be
    accessible on the drive if he takes it back under warranty. Time to get
    the grinder out I think.
    DozynSleepy, Feb 17, 2010
  13. Switters
    Switters Guest
    Exactly!
    Seriously though, a new PC is on the cards at some point, but I can't be
    arsed at the moment as I don't really use it that much these days. The
    laptop gets used more.
  14. Switters
    Catman Guest
    Indeed. OTOH that disc is clearly fucked. Restore from backup.
    www.cuore-sportivo.co.uk
    Catman, Feb 17, 2010
  15. Switters
    Switters Guest
    Ohhh useful. Ordered.
    The heads sound like a machine gun, obviously just a bit quieter. I've
    managed to get it running briefly. Soon as I plugged it in to the
    laptop, Linux alerted me that it was about to fail. Managed to wipe
    some stuff, but other files it wasn't playing ball on. Diags failed at
    first attempt. Clak-clak-clak-clak-clak-clak.
  16. Switters
    Catman Guest
    Always a sod not being able to sterilise. OTOH it *REALLY UNLIKELY* that
    anyone else is going to give a toss about getting your data of a broken
    disc on the off chance that it's of interest when they probably have a
    stack feet high of working ones.
    IYSWIM
  17. Switters
    ginge Guest
    Take a 4 inch nail, put the pointy bit on the top cover of the drive
    and whack with a hammer, listen to the delicate sound of smashing
    platters. Shake and repeat until a sufficient level of granularity
    replaces paranoia.
    Easy.
    ginge, Feb 18, 2010
  18. Switters
    Catman Guest
    Bit hard when it's going back for a warranty claim, though....
    Catman, Feb 18, 2010
  19. Switters
    Dave H. Guest
    Degauss it? AC buzzbox welder, wrap the electrode lead around the disc a few
    times, short electrode to work clamp for a few seconds at max current....
    Case might get a bit warm though.
    Though some of us have access to the real thing, of course. For MoD values
    of sterilise, it's degauss - hammer flat - chopsaw - furnace....
    Dave H., Feb 18, 2010
  20. Switters
    Switters Guest
    I'm probably being overly paranoid, but hey, it's what I get paid for.
    *ding*
    Switters, Feb 18, 2010
